How heavy is stock flywheel?
Old Mar 19, 2002 | 12:25 AM
coop's Avatar
I am looking to upgrade my clutch, and I see there is the ACT Street/strip + 10lb flywheel combo, is that a good upgrade to do while the clutch is being upgraded?
Is it ok to have the clutch installed at a transmission shop? or Mazda Dealer ($$$$) or any suggestions? I don't live near any rotary shops...
Is the 10lbs a significant reduction in flywheel weight?
Is the fact that it is an aluminum flywheel a problem? is that strong enough for FD applications?
Thanks
-Dave
Old Mar 19, 2002 | 12:35 AM
spooledUP7's Avatar
There and back again
Yes it is a significant difference. Something like 9 pounds. If you have the money, let a shop do it. If not, do it your self. It's not that bad. Do a search to find out the best way to do it. My advice. Propane torch and turn up the pressure on the impact wrench.
cristoDathird
28
May 30, 2019 08:47 PM
sYnth.
Aug 19, 2015 06:27 PM
Clacor
Aug 14, 2015 09:17 AM
