Sub Zero Starting System
Old Mar 18, 2002 | 11:14 PM
crasher2's Avatar
Question Sub Zero Starting System
I am thinking about disconnecting my sub zero system because i think that is giveing me troubles starting my car. Really likes to flood out a lot. If anyone know s about this will you let me know.
Thanks
Old Mar 18, 2002 | 11:48 PM
rx7_turbo2's Avatar
Professor D.P
The flooding is probably your injectors leaking, it's pretty common.
Old Mar 18, 2002 | 11:57 PM
crasher2's Avatar
thanks, i will check them out. i was wrong about the sub zero thing i want to disconnect my cold start system. DOes anyonre know anything about that
Old Mar 19, 2002 | 12:25 AM
Sub-zero starting assist is a joke. I don't think my 7 has ever even used it. And I filled it two winters ago! I've never had problems starting it in 0 degree weather either!
Old Mar 19, 2002 | 01:19 AM
niner's Avatar
yeah man, rip that thing off and plug the vacuum hose from it. your problem is probably not related to that though
Old Mar 19, 2002 | 08:34 AM
Vroomaster's Avatar
Ya, the last time I put my rex in the dealership, they removed the tank and disconnected it.
Old Mar 19, 2002 | 11:33 AM
rx7_turbo2's Avatar
Professor D.P
On the side of the bottle closest to the front of the car opposite the fire wall there will be a clip, just unplug this. If you have ABS it might be a pain but you can also remove the bottle if you feel so inclined.
cristoDathird
28
May 30, 2019 08:47 PM
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
