RA omp adapter and adjuster
Old Mar 6, 2007 | 07:53 PM
felix_is_alive's Avatar
Has anyone tried this on the 20B
http://rotaryaviation.com/oil_inject...s.htm#adjuster
would this be a better alternative to pre-mix?
Old Mar 7, 2007 | 12:46 AM
Rhode_Dog's Avatar
\m/
Patman did a write up on something similar https://www.rx7club.com/showthread.p...ht=omp+adapter
here is a nother thread from the 3rd gen section
Old Mar 7, 2007 | 03:26 PM
i spoke today with richard sohn , the guy that sells the RA omp adapter , as he explains to me ,
You can use this , adapter , with the adjuster and you can draw fresh oil (twostroke) form a separate tank so your`e not using engine oil ,
Tha adjuster lets you literally adjust the amount of oil metered into the engine , he spoke of it beeing able to djust from lowest to max with an adjustment screw , also he did mention it can go 100:1 and 140:1 ...so there might be something there
this does seem to be anlternative to pre-mixing
Old Mar 7, 2007 | 03:56 PM
patman's Avatar
Resident Know-it-All
yep, thats the idea. my mod does the same thing, but without the adjustability. Personally im not sure why anyone would want to run less than 100:1. If you have the money, i'd grab theirs tho, its easy. if you want to save $100, check out my thread linked above.
Heres a overview I did about the lubrication system and modification in general:
http://howto.globalvicinity.com/gv_w...=255&co=1&vi=1
pat
20B Forum
21
Mar 22, 2022 01:00 PM
cewrx7r1
15
Aug 6, 2018 11:41 AM
