Power FC PFC Noob has questions
Old Mar 3, 2007 | 09:24 PM
Talking PFC Noob has questions
Ok i just installed the PFC w/ map that put on for my car but have a few basic questions.
after the warm up cycle is surging to 1500 rpm, then backs to 1000 and surges back does this every few seconds.
how far should the knock bar go or not go.
the english copy manual i got is pretty crypic on a few things. So if there is a good source to read, point me to it.
Thanks.
Old Mar 3, 2007 | 09:28 PM
another questions.
I pulled the pins for the 4 wires to be removed, but wanted to check that those are the pins when looking at the ECU harness receptical. Not the front of the harness.
Old Mar 3, 2007 | 10:06 PM
DaleClark's Avatar
RX-7 Bad Ass
Read the PowerFC FAQ -
http://www.clubrx.org/media/pfc/PowerFC_FAQ.pdf
Your questions should be covered there.
Dale
Old Mar 7, 2007 | 02:25 AM
JP's 93 fd's Avatar
Dale
hey dale, what if the ac or heat blower doesn't work. How would you do the idle learning process?
Old Mar 7, 2007 | 09:49 AM
cewrx7r1's Avatar
Eye In The Sky
Did you understand what the three idles are used for?
If one is for AC operation and your AC does not work/come on, then it would never be asked to do it's function and thus is not a problem.
As for electrical load, we have the driving lights, rear defroster, radio, brake lights, etc.
Just like you will never be asked to do brain sugery and thus you do not have to worry about not being able to do it.
Old Mar 9, 2007 | 07:05 PM
RX7LINK's Avatar
RX7FD3S
even if they're not working, i would just time the process like described in Dale's instructions.
my AC fan's broken but my primary cooling fan works. so i just timed each process, and after the learning process is done, my rpm settings in PFC for fan1 and fan2 have 100(maybe 200, i gotta go check my car) rpms difference. which is how ur rpm react w/ ur stock ecu when ur AC on.
another words, they work fine, even w/ one broken radiator fan. broken blower in ur case
... but yeah.. summer's comming.. i'm getting that fixed asap
Old Mar 13, 2007 | 09:49 PM
hey guys i have set the idles but it still does it for the non load. Meaning it follows the setting for A/C and eletrical and idles where i set it. But it will not follow it for the no load, it is actually going fuel cut because the injector duty goest to 0%. adjusted the full cut resume as well to try to make the injectors come on hopefully go to a graceful idle instead of surging but wtf..
Old Mar 13, 2007 | 10:39 PM
cewrx7r1's Avatar
Eye In The Sky
List all of your PFC idle settings, and also give us your two TPS voltages (in the PFC manual) with the throttle fully closed (not held open by the fast idle cam/hot wax rod).
_Tones_
May 25, 2021 05:37 AM
whinin
Mar 30, 2019 07:53 PM
24seven_dada
20
Nov 10, 2018 12:03 PM
Nosferatu
Sep 5, 2015 02:13 PM
