Microtech Runtime error 13!"#¤&"
Old Mar 1, 2007 | 06:09 AM
Vegard's Avatar
Well as the topic says I get runtime error 13 when I try connecting to the microtech... lt10s with x4 if that matters..
I have the dongle connected, usb adapter and all that, and this was working before i formated the computer...
Im using the software from the CD that I got with the dongle, and I've tried the software on the official site.
Also I can't change the com port settings for some reason in the Device Manager?!
Both com3 and com4 get the "runtime error 13" (com 3 and 4 is the com is sets to when I plug it in the USB)
Any help?
https://www.rx7club.com/attachment.p...d=224659&stc=1
Old Mar 1, 2007 | 06:23 AM
Vegard's Avatar
Im trying this now:
Originally Posted by projectredsuns
Ok this is info needs to be stickied. But I will say it again. If you use a 9-pin usb adapter. You need to uninstall microtech, uninstall all your 9pin-usb drivers/software. And start fresh. Install the usb adapter configure it to port 1. Restart the machine. Reinstall microtech and it should work just fine.
will get back to you with result...
Old Mar 1, 2007 | 06:54 AM
Vegard's Avatar
No go so far... same problem "runtime error 13"
Old Mar 2, 2007 | 05:33 AM
Vegard's Avatar
Originally Posted by teachermechanic
microtech
Hi, just change you computer language.
Pass one year i had same problem.
I got this in a pm, and it worked!
I changed all my regional and time settings to United States, and it worked...
Thanks for the help teachermechanic!
Vegard
Old Mar 2, 2007 | 08:03 PM
RotaryBuddha's Avatar
CURVE OF CONSTANT WIDTH
wow thats weird that the microtech program needed to be set for a different region to work correctly.
glad you got it working
Old Mar 3, 2007 | 07:18 AM
teachermechanic's Avatar
Vegard
No problem, i don't understand why it's not sticky.
befarrer
15
May 19, 2022 10:44 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
ZacMan
Sep 19, 2015 09:20 PM
scissorhands
Sep 16, 2015 01:25 PM
