Has anybody hooked up nos to the stock interooler???
Old Mar 17, 2002 | 11:21 PM
Import Convert's Avatar
The air in your intercooler has already gone though the turbos. Fogging is when a nitrous plate is installed beneath a carburator. If you are going to install nitrous, put the nozzle in the elbow by the throttle body.
Old Mar 18, 2002 | 12:06 AM
the_saint's Avatar
do you mean spraying the IC with Nitrous oxide? It might make a bit of a difference, but I would rather upgrade the IC. You will run out of nitrous oxide but the upgraded IC will always be there.
The upgraded IC makes a huge difference, and is a great piece of mind.
thesaint
Old Mar 18, 2002 | 11:57 AM
martini's Avatar
nitrous is expensive, remember.
Old Mar 18, 2002 | 12:00 PM
SPOautos's Avatar
Hey, where did my $$$ go?
If I were to spend the money for nitrous I'd hook it up correctly. You'll get colder intake air by injecting it into your mixture rather that just spraying the IC.
If you just want to make your IC cold use a bottle of CO2
Later,
STEPHEN
Old Mar 18, 2002 | 05:17 PM
rxrotary2_7's Avatar
like SPO said. use a 20lb bottle of CO2. its about $9.50. and dont feel like spending money on an IC. do what i did, use an isuzu npr IC. can be had very cheap and flow great. use the search function to find more info in the IC if you are not familiar. (that is if the search function is working when you read this )
Old Mar 18, 2002 | 11:07 PM
spooledUP7's Avatar
There and back again
Let's see a picture of this. I am curious.
Old Mar 19, 2002 | 08:31 AM
if you can give me a few hours until u get done work, i can take pics of one in an fd, in an rx3 and one other fc other than the one i am going to post
this one is a pic of one installed in a 91 vert. has 3in inlet and outlets.
do you need the flow rates of the IC? yeah?
ok....The NPR IC: at 329cfm and 290°F on the inlet side of the IC, the
pressure
drop is 0.09psi. The outlet temp is 130°F, heat rejected is 55553
BTU/hr, and
the calculated heat exchange area is 1404 square inches.
Old Mar 19, 2002 | 10:40 PM
spooledUP7's Avatar
And how do those numbers compare to the $1500 - $2500 RX-7 specific IC? Or, better yet, how do they compare to the stock IC?
Old Mar 19, 2002 | 11:11 PM
Bacon's Avatar
IRS 4 Life
kieth who made the piping for the vert???
Old Mar 20, 2002 | 08:04 AM
i dont know....why dont you find me the flow rates for one of those and we can compare. but an ic that is 14in tall by 22in wide by 2.5 in thick with 3in in and outlets has to flow better than that stock pos. and for the price i can get these for...
len, they are just random pipes that were sitting around jim's shop. one of them is from a 300z's intake. the rest are aluminum (the z's is plastic) the ones going under/inbetween the rad. is just 3in rubber hose. yeah its kinda rigged for now, just a *sketch* of what is needed for gambordella to do the pipe work.
i'm not quite done on mine for my fd. my turboII's is done though. and the tII was run with the ic upright as opposed to jim's run *upsidedown*.
hey len, you know what i wanted to ask you...do you happen to have an extra set of stock primary 550's? let me know. if i dont hear back from you on here, i will hunt your *** down, put your food in a freezer and make you eat it COLD!. either that or i'll just call you.
Old Mar 20, 2002 | 08:23 AM
Bacon's Avatar
IRS 4 Life
lmao...atuall all i got is a extra set of 850 secondaries...sorry bro ill see what i can find though
