Could over filling the coolent cause it t leak when it had never leaked before?
Old Mar 17, 2002 | 06:28 PM
c00lduke's Avatar
I went to check my coolant level and it is like and inch or 2 above the Full symbol, and it is leaking right under the coolant tank. Could having to much cause it to leak? What are some things i should test?
Thanks
~Luke
Old Mar 17, 2002 | 07:44 PM
GsrSol's Avatar
Z06 powered FD
Is it leaking under the overflow bottle? Passenger front side of the car. If so it is fine, it just builds up pressure and will spit out the excess once it gets to a certain level.
Old Mar 17, 2002 | 07:48 PM
rotorhead333's Avatar
The coolant overflow bottle is a 2-piece. The neck is affixed to the bottle by a rubber tape gasket. Mine was leakin too, dry rotted actually.. I pulled it out and fixed it myself, or you can buy a new bottle.
Old Mar 17, 2002 | 09:31 PM
Fritz Flynn's Avatar
All out Track Freak!
Thats correct theres a small hole in the top that bleeds off any overflow in the overflow tank. Which I assume prevents pressure from building in the system cuz hot water expands quite a bit just another reason to switch to evans coolant.
Old Mar 17, 2002 | 10:33 PM
kelrx7r1's Avatar
TNC
Talking
yup happened to me and im a jerk cause i filled it up every morning thinking it was leaking from there but was my water pump going
south.
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
