Sponsored by: CARiD
HELP Weber/Half bridge question!
Old Mar 17, 2002 | 05:54 PM
Hi, I posted this in the performance section and got no replies so here goes-Im building a half-bridge 12a because i still want to use the stock 2 piece apex seals. And for carburation i plan on using my 45mm sidedraft Weber. My question is will this setup work ok?. Some people in the first gen. forum said it wont work very good because of the 2 barrell Weber. Anyone ever try this setup?.
Old Mar 17, 2002 | 06:44 PM
Newbie
i cant answer your question but i want to know how you connected the metering pump rod to the throttle linkage
Old Mar 18, 2002 | 02:09 AM
Rotortuner's Avatar
Undercover
Ya its called premix.
CJG
Old Mar 18, 2002 | 02:52 AM
peejay's Avatar
Old [Sch|F]ool
Premix is better for the engine, anyway... you know that you're injecting clean, designed-to-burn lubricant instead of nasty ol' sump oil.
As for linkage... which intake manifold do you have? The linkage should come with the manifold/carb setup.
Old Mar 18, 2002 | 07:19 PM
Hey guys what about my question? My weber came with the rod to connect to the OMP.
Old Mar 24, 2002 | 08:30 AM
swoop's Avatar
Webers are the best carb set up for a rotory.
Who ever told you it wouldn't work must have been ****** with you, or they just don't know **** about what they're saying.
Old Mar 24, 2002 | 09:53 PM
REVHED's Avatar
Hunting Skylines
It will work but a 45mm DCOE is too small for a half-bridge 12A.
And one of the benifits of a half-bidge is the ability to use a four-barrel carby to take advantage of the staged secondaries. ie. Good response from the street-ported primaries down low and mid/high rpm power when the bridged secondaries open up.
Personally, I would run some sort of 4-barrel or then just get a 48 IDA Weber.
_Tones_
May 25, 2021 05:37 AM
josef 91 vert
14
Sep 17, 2015 09:22 PM
dillrx7
Sep 7, 2015 09:38 AM
Nosferatu
Sep 5, 2015 02:13 PM
