need some help pls
Old Mar 17, 2002 | 12:39 PM
Rx-7$4$me's Avatar
need some help pls
After using the search engine for about an hour with no luck I have a few basic questions for everyone. K&n Fuel filter/oil filter im getting. What coolant, thickness/brand of oil should I use? NGK plugs but which ones and where should I buy them from.. .or other plugs? what kinda plug wires? what kind of downpipe/ boost gauges are the best?
I appologize for the re-re-re-re-re-re asked questions
Thanks alot 3rd gen peeps!
Old Mar 17, 2002 | 12:50 PM
m_snoby's Avatar
Most of those questions could have been answered by the search. Anyways stay with stock plugs and wires, look in the owners manual for oil, I use 10w30 but I'm in the south. Downpipe and boost gauge question, your going to have to answer that yourself. It's all personal preference.
Old Mar 17, 2002 | 03:36 PM
rynberg's Avatar
Re: need some help pls
Coolant: any ethylene/glycol and DISTILLED water
Plugs and wires: stock type (NGK)
Downpipe: being in Chicago, definitely get a stainless steel pipe, www.m2performance.com or www.rx7.com
Boost Gauges: too many variables for a simple answer, I'm waiting on the new custom run of Omori gauges that will be nearly exact matches to the oem gauges
Old Mar 17, 2002 | 04:34 PM
cash money's Avatar
Old School Member
check out evans coolant, its waterless, its sort of contreversial if its worth the extra money, i think it is, you can judge for youself
