West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Shooting flames at idle
Old Feb 22, 2007 | 01:07 AM
racatech's Avatar
racatec
okay, so my friends s5 n/a shoots flames at idle every 4 seconds and blows thunderous flames at redline shifts. what is the cause. its pretty crazy
Old Feb 22, 2007 | 01:17 AM
RotaryEvolution's Avatar
Sharp Claws
extremely rich conditions during shifts and misfiring at idle.
neither are really desirable but on high HP setups shooting flames at shifts when really pushing the car is natural but shooting flames at idle is a big finger at a lack of care of the car.
Old Feb 22, 2007 | 01:28 AM
Sgt. Pepper's Avatar
Why is it natural on just high horsepower cars?
Is it not normal that my NA FC shoots flames sometimes when I shift above 7K RPM just because it is pig rich from the factory and not having a cat allows the excess fuel to go through my exhaust?
Old Feb 22, 2007 | 01:35 AM
ohayou88's Avatar
yea that part is true I have NA single exhaust no cats and I shoot flames.
BUt shooting flames at idle is a combination of extremely rich and some car care problems.
try posting in the 2nd gen tech section to get more info
Old Feb 22, 2007 | 01:47 AM
DriftingB26RX7's Avatar
Porsche-Hunter
I shoot huge flames when I shift at 65 or 7 when I'm running it hard....everytime and even when I let off the gas
Old Feb 22, 2007 | 01:51 AM
Sharp Claws
n/a's are rich from the factory so that is fairly normal also but with no cats you actually are losing power so i don't necessarily consider them running right unless tuned. they run as designed, which helped to keep the cat in one piece but without it there is no need for them to run rich any longer.
Old Feb 22, 2007 | 03:58 AM
The Only SlidinRX7
My old S5 used to pop blue flames at idle, but it was because I had a blown apex seal and I was trying to limp it off the track lol. When everything was running all good it would only pop tiny flames on high RPM shifting or getting off the throttle at high RPMs going into corners. At the time I was only running single Apex N1 with no cats.
Basically high HP car run on massive amounts of fuel. ie. The more air and fuel you can cram into a chamber with the correct Air:Fuel ratio, the bigger the bang will be. I guess you could call shooting flames at high RPM's "normal" IF you're running straight pipe exhaust. When I was running N/A it would shoot out small flames every now and then. After I did my TII swap I could shoot massive flames all day. I never really got around to tuning though. Kept the SAFC tuned rich until I could get a chance to tune it properly, but ended up selling the project before I could finish. We lost our track here in Hawaii and slowly I started to lose interest. Anyway, I would think that tuning a car at higher RPM's to be a LITTLE on the rich side would be a safety precaution. The unburnt fuel will flow out of the motor and through the exhaust. The more open the exahust, the more farther the unburnt fuel can travel before evaporating or being burnt up in the piping.
Old Feb 22, 2007 | 04:10 AM
teddyrx2's Avatar
One Luv "Till The End"
Shooting flames at idle is not a good it's running to rich and is not good on the motor but shooting flames on full throttle is cool it doesn't take a high horse power car to do that.
Old Feb 22, 2007 | 02:59 PM
mannyvidal's Avatar
come get some.....
see this is logic a blown apex seal will make the car spit out flames @ idle what does not make any sense TEDDY is saying that on full throttle shooting flames is cool. if you are shooting flames a full throttle it means that your tunning is out of wack. too much fuel not enough air and too little spark those are a couple of things that come to my mind ... come on all you have to do to shoot flames is lay off the throttle a bit and then hammer it back down everybody knows that .
so what i would have your buddy do is take a compression test to make sure ur apex seals are ok, because no matter how rich that motor is @ iddle it should not flame out every four seconds..............
Old Feb 22, 2007 | 03:05 PM
Sharp Claws
i mentioned a properly tuned car, only when making decent numbers should well tuned cars still pop flames all the way past the tips, on lower HP cars it is only because they are running stupid rich or the timing is way off.
Old Feb 22, 2007 | 03:07 PM
mannyvidal's Avatar
come get some.....
[QUOTE=Karack]i mentioned a properly tuned car, only when making decent numbers should well tuned cars still pop flames all the way past the tips, on lower HP cars it is only because they are running stupid rich or the timing is way off.[/QUOTE
TEDDY you still have time to learn something lol
Old Feb 22, 2007 | 03:50 PM
socalrotor's Avatar
stuck/leaking primary injector would be my first suspect.
Old Feb 22, 2007 | 06:14 PM
mannyvidal's Avatar
come get some.....
that would still not be enough , ive had cars with raw fuel coming out of the exhaust while its @ idle because the floats were stuck and still no flames, shoot it happened to teddy's dad rx7 when i first built it about six years ago, back then in the day's when teddy use to loom in my garage all the time now he thinks he is big time and i hear he thinks he can smoke me ..... like it say's below my aveter little buddy "come get some" youve got my # and know where i work and while your at it y dont you bring me the money you owe me for porting those rotor housings 4 ya
anyway goin back to the flaming exhaust last year during the nhra sport compact season opener in west palm beach fl we had an injector mess up on jesus padillas all motor rx7 and still no flames from the muffler @ idle call me crazy but i belive its something else
Old Feb 22, 2007 | 06:47 PM
socalrotor's Avatar
If a FPR takes a crap it can dump fuel into the vac system. Pull off the vac line going to it and see if it is leakiing fuel on the vac side.
Old Feb 22, 2007 | 09:25 PM
racatech's Avatar
racatec
thanks
Old Feb 23, 2007 | 01:18 AM
Bob_The_Normal's Avatar
Hey Karack, is it not common to run a (fairly) rich fuel map on most turbo applications?
I don't blame anyone that shoots flame on shifts and has a turbo... I call that fire "engine insurance" heh. Am I wrong here or what?
--Gary
Old Feb 23, 2007 | 01:32 AM
Sharp Claws
it is safer but you will lose some gas mileage.
Old Feb 23, 2007 | 03:16 AM
This is a rotary forum, we don't know the meaning of "MPG" ;P
--Gary
Old Feb 23, 2007 | 08:40 AM
Mutaku's Avatar
I fix planes...
--Gary
all we know is car mileage =P
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
Bauer778
Nov 4, 2015 04:42 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
RotaryBobby
Sep 10, 2015 01:33 PM
