wires from engine bay to interior by passenger side???
Old Mar 17, 2002 | 10:07 AM
puma's Avatar
canadian monster
Anybody know how to make that? I know where to pass on the driver side but i can't seem to pass my hand behind the ABS unit. How do you guys pass wires through the firewall on that side of the car?
thanks a lot
puma
Old Mar 17, 2002 | 10:20 AM
luneytune's Avatar
Hi Puma, I poked a hole through the Wiring harness gromet for the ECU. I loosened the 10mm nuts holding the ABS down and then slipped out the heat shield, you can then get your hand in there. I also put a little silicon caulking on the wire where it passes through to reseal the hole especially if you have more than one wire. It isn't the easiest thing to do but what the hell.
