Power FC bouncing idle on warm starts
Old Feb 14, 2007 | 01:36 PM
rockshox's Avatar
I often get the problem where the idle bounces around from about 600 to 1500rpm, and almost dies on warm or hot starts. It returns to normal if i rev the engine a couple times or after a few minutes. Any ideas what might cause this? Is it a known issue?
Old Feb 14, 2007 | 02:34 PM
blackB's Avatar
Fly bye...
OK I'm not the only one....
My car starts fine, cold/hot... but after I drive it around, park it and not let it completely cool down, i get the same symptoms...
I hope its an easy fix...
Old Feb 14, 2007 | 02:42 PM
cewrx7r1's Avatar
Eye In The Sky
All of these are an indication that your hot or cold idles are not properly adjusted. Either too much or too little air or fuel!
Time to seacrh this forum, and use your commander and screwdrivers and play mechanic. You could buy my notes for much much more info.
Old Feb 18, 2007 | 02:58 PM
R-R-Rx7's Avatar
Rotor or no motor
i had the same problem guys..
i cleaned the throttle and changed the idle valve...
and it was gr8
con
Microtech
30
Apr 23, 2016 06:37 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
85TIIDEVIL
Aug 25, 2015 12:09 AM
zuesskroph
Aug 13, 2015 06:05 PM
