my rotor housings plz good advice!
Old Feb 12, 2007 | 05:30 PM
fd rotar tt's Avatar
ok i had my housings bridge ported i hope to be assembleing my engine soon, i currently have atkins 3mm rebuild kit, everything dynamically balanced, and new bearings main and rotor. now heres the my problem my rotor housings at the bottom of the exhaust stroke right where it meets the irons has like a 1mm line or gruve or something! on both housing pretty much in the same spot. now my question is do you think it will be ok? look at the pics let me know how you guys feel.
Attached Thumbnails my rotor housings plz good advice!-picture-001-wince-.jpg   my rotor housings plz good advice!-picture-003-wince-.jpg
Old Feb 12, 2007 | 07:39 PM
patman's Avatar
Resident Know-it-All
thats pretty normal for older housings, but i personally wouldnt put those in an engine that i went to the trouble to balance and everything... they will work fine, but eventually that groove will grow, and they will never make quite perfect compression. its really your call, they wont blow your motor or anything if thats what youre asking...
Old Feb 13, 2007 | 07:30 PM
any one else have any thoughts?
Old Feb 13, 2007 | 09:05 PM
rotaryinspired's Avatar
They are probably good for another 50K. Like he said above its your call. If it were my car and I wanted it to last for a couple of years I'd do it. For someone else no.
Old Feb 14, 2007 | 08:37 PM
not sure if you guys are seeing it right. its hard to tell by the pics, but if you look real hard theres a kind of a goldish line, about 3 inches long and 1mm thin. im not talking about the common wear mark from the corner of a two piece apex seal. its kina actually like a piece got ripped off. maybe you do see, but im still kinda new to building my own rotary.
Old Feb 15, 2007 | 04:50 PM
Tom93R1's Avatar
gross polluter
Exactly like patman said. Personally I wouldnt use them in a motor I cared about such as a customer car or something I put enough time into to balance. I might use them in a beater car but thats about it.
I recommend new housings if possible.
Ciclovnz
Oct 18, 2015 03:04 PM
cdn
14
Sep 10, 2015 06:23 AM
Brice_Brice
Aug 18, 2015 10:42 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
