93 octane good to what boost?
Old Mar 16, 2002 | 01:22 AM
Crazy_Jake's Avatar
At what boost level do you need to think about going to a higher octane?
Old Mar 16, 2002 | 11:26 AM
Crazy_Jake's Avatar
Old Mar 16, 2002 | 12:24 PM
RecKleSs's Avatar
Adrenaline
If you plan on pushing 13psi or higher you have to upgrade your fuel system. For example, injectors, and fuel pump. Also, you will need to upgrade your ECU. You will be fine with 15psi with 93 octane any thing higher you should use a much higher octane, to make sure you don't blow your engine.
cristoDathird
28
May 30, 2019 08:47 PM
alphawolff
Nov 17, 2015 05:57 PM
rx7brandon
Aug 16, 2015 10:55 AM
