Need Help To Remove Oem Side Skirt!
Old Feb 10, 2007 | 06:43 PM
jef57's Avatar
Unhappy Need Help To Remove Oem Side Skirt!
Im trying to remove these, but they are stuck on with some type of glue/adhesive....
any idea to remove them ,
thanks for your help
Old Feb 10, 2007 | 08:40 PM
adam c's Avatar
Cheap Bastard
What exactly are you trying to remove? There is no OEM side skirt on USA models.
Old Feb 10, 2007 | 09:02 PM
badddrx7's Avatar
All Spooled Up
This is probably 3m type double face adhesive tape. Take a hair dryer and apply heat to an area at the front and carefully apply pressure to remove it. Keep the heat on the area while removing the panel. After it is off you need to remove the adhesive with an approved paint safe adhesive remover. See a body shop
tom
Old Feb 10, 2007 | 09:41 PM
SLOASFK's Avatar
Top's always down
that's great and all, adam, but he's in France.
Old Feb 11, 2007 | 05:34 AM
jef57's Avatar
YES I'm French, i'm going to try with hair dryer
thanks
Old Feb 11, 2007 | 10:52 PM
cabaynes's Avatar
Old and grumpy
get some strong fishing wire, and put it between the edge of the sideskirt and the car... then get some gloves on so you don't cut your hands and pull the fishing wire down the side of the car, separating the side skirt... this has worked for me in the past, but if not then i would recommend heating them up and trying it again
Old Feb 12, 2007 | 02:35 AM
eff_three_see_es's Avatar
lycanthrope
actually the finishline dealer installed aero kit is oem, and it has that nasty goo on the side skirts and bumper caps. i jsut got done swaping it from my 88 to my 86.wait for a hot day or use a blowdryer
sYnth.
Aug 19, 2015 06:27 PM
