Finally tagged and on the road. Need help with door seals.
Old Mar 15, 2002 | 09:01 AM
Cool Finally tagged and on the road. Need help with door seals.
I finally got the SE licensed and cruising. What a great ride! I was thinking about getting some sort of a personalized plate, you know 80CID or something. When I went to the license bureau the next plate was 123 RNR . What a perfect gift! Running through the gears is definitely the way to rest and relaxation! I said that that was a perfect plate for my rex and saved the extra $$$.
It seems a set of door seals will be in order after some hiway cruising last night. Anybody have experience with which are the good ones available?
Old Mar 15, 2002 | 09:56 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
well i got mazda seals and they broke in less than a year. theres door seal on ebay all the time.new for like 54$. search RX-7
treceb's Avatar
victoriabritish.com
Old Mar 15, 2002 | 12:02 PM
hanman's Avatar
Ditto on the Mazda seals, cost me $110.00 and broke in three months.
ebay or V.British.
hanman
Old Mar 15, 2002 | 01:36 PM
Thanks, Everything I've gotten over the years from V. Brit. has been of good quality. I have watched the ones on ebay and wondered if anybody had had experience with them.
Old Mar 15, 2002 | 03:40 PM
branca's Avatar
door seals
I bought a pair of the ebay door seals last year when they were $45.00. They fit well and seem to be holding up ok so far, plus kept me warmer tihis winter
http://www.1aauto.com/cgi-bin/item.c...0&model_id=526
Old Mar 15, 2002 | 03:42 PM
yayarx7's Avatar
Are you Nucking Futs?
I am going to get a set of those ebay seals. cheaper than mazda.
Old Mar 15, 2002 | 07:08 PM
85RX7GS's Avatar
I'll be getting those on ebay as well. I hope they hold up.
Old Mar 15, 2002 | 09:14 PM
For whats its worth, i bought a set for my 85 easy to install but make sure you run a small bead of silicone on it else it may leak, i forgot to do that & ended up with a wet carpet after a heavy rain, glad to say no more leaks & alot quieter.
Old Mar 15, 2002 | 09:16 PM
ps. bought them on ebay, seller shipped very fast
Old Mar 15, 2002 | 10:37 PM
Jason Guthrie's Avatar
The top part of my stock seals are crunchy and split open(though they do not leak) which makes them quite ugly. I would pay the money to replace these no problem. So what's involved with replacement?
1) Open Door or remove door?
2) Yank the old ones off with bare hands?
3) Bead groove with a silicon based sealant?
4) Hard to get back on/in groove? 1-2hours or what?
Old Mar 16, 2002 | 11:03 AM
rotorhead's Avatar
got mine from mazdatrix. genuine mazda oem parts. theyve been on a year and are holding up fine. the seals are held on by clips. there are a lot of pegs that poke out of the door seal, and these pegs pop into matching holes around the perimeter of the door. very easy to do and not very time consuming. maybe an hour, tops.
Old Mar 16, 2002 | 11:53 AM
Pittdp's Avatar
I bought mine there as well and have had them on for over 1.5 years now. I also use 303 protectant on them to keep them like new.
Old Mar 16, 2002 | 12:24 PM
Sounds like there are lots of options and no reason to put the job off.
Thanks Guys!
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
