45 dcoe
Old Jan 29, 2007 | 05:17 PM
alex_rock66's Avatar
Question 45 dcoe
Im gonna instal a weber 45 in my 12a bridge ported and i need some advice on the jets setup.
If anyone of u guys have this setup help me out, tell me how big can i go.
before this i was runnig a holley 650 and is a powerfull engine.
Plus now I got a 75 show wet kit that im also gonna put on so, I need your help.
Old Jan 29, 2007 | 05:44 PM
jgrewe's Avatar
GET OFF MY LAWN
General rule for weber jets is venturi dia x4 for mains, take that and add about 50 for airs. Hopefully you have around 40mm chokes to feed that engine. With that in mind I've found rotary's like more main and less air correction so around 190-200 mains and 230 or so airs. This will get you close but some dyno time is your best money spent for tuning, don't believe your "butt dyno".
Old Jan 29, 2007 | 05:49 PM
trochoid's Avatar
Old Fart Young at Heart
Too small, you should be running a 48mm instead.
Old Jan 29, 2007 | 05:56 PM
Kim's FB's Avatar
WWW.SUPERCHARGED-RX7.COM
^My thoughts also.
Old Jan 29, 2007 | 09:34 PM
680RWHP12A's Avatar
same here, a 45 carb will choke a bridge, i would use a 50mm carby
hi kim
Old Jan 29, 2007 | 11:12 PM
well
the 45 its the only thins i got right now so mind as well make the best of it.
thats why i need some suggestions in how to yet it.
Old Jan 30, 2007 | 03:56 AM
Hyper4mance2k's Avatar
The Shadetree Project
run it w/o the main chokes drive ability will suffer, but it can and has been done. I's say 210 for main jets, 140 a/c, 55 pump jets, and 65f9 idle jets.
Hyper4mance2k
84
Feb 1, 2008 05:32 PM
