How can I get rid of all this Emissions Garbage!!!
Old Jan 27, 2007 | 12:13 AM
Burnitclean82's Avatar
Newbie
I'm fairly new in the RX-7 world and right now I just want to get rid of the failing emissions system that is just to me, dead weight. Can anyone give me an idea as to what I need to do to get rid of the rats nest and all that?
Old Jan 27, 2007 | 12:21 AM
85rx12a's Avatar
fasterthanaspeedingticket
check out the FAQs page, or you can go to mazspeed.com they have a sweet tutorial on the removal of the rats nest.
although some have had problemes after removing the nest.... myself included good luck
Manntis's Avatar
add to cart
http://maz_tutorials.ten15.net/Tutorial_1.pdf
Old Jan 27, 2007 | 12:35 AM
-=DanK=-'s Avatar
Yell at it and scare it away.
Old Jan 27, 2007 | 03:40 AM
Rx-7Doctor's Avatar
Do you have the stock exhaust manifold and catalytic converters on the car?
Old Jan 27, 2007 | 10:17 AM
Newbie
yeah. It's all stock. What I plan on doing is replacing the exhaust system with an RB setup and put in a weber 45DCOE carb.
Old Jan 27, 2007 | 11:19 AM
Rx-7Doctor's Avatar
I recommend you wait until you start your mods before you remove the rats nest. If you do the Rb exhaust and wait to do the carb then I recommend at that time you remove the air pump, air control valve then use the plate that is supplied to block off the opening from the valve. When you do the carb then you can just remove all of the nest. The archived tutorial will guide you thru that.
ls1swap
Jun 3, 2024 03:25 PM
renjiv2
57
Jan 25, 2024 03:34 AM
RedBaronII
Sep 20, 2015 11:29 AM
