Running an 13B w/out oil.
Old Jan 26, 2007 | 03:07 PM
luism12lm's Avatar
Question Running an 13B w/out oil.
II bought an SE 13B and the previous owner ran the engine w/out oil. The engine doesn’t move at all. I’m thinking about rebuild the engine (w/some upgrades) but before I start this project I will like to know what to expect from this engine. What parts can I re-used (rotors, springs, housings, plates, etc.) from an engine that ran w/out oil? What do I need to buy? I know there are a lot of experience guys out there who probably had the same problem. Any help will be appreciated.
Thank you,
Luism12lm
Old Jan 26, 2007 | 03:20 PM
AdamAnt's Avatar
Talking
The dip stick may still be ok!
Old Jan 26, 2007 | 03:30 PM
AdamAnt's Avatar
But seriously, so much of the engine cooling comes from the oil, I don't think any internal engine parts will be usable. A good rebuild on a rotary is not cheap. Cheap ones typically last about 6 months to 1 year.
With no oil the engine would have generated extreme heat and friction that would destroy almost everything. Rotary's don't like getting overheated!
If you can't turn the e-shaft the engine is locked good. Even with blown apex seals you can usally still turn the engine.
I forget how to do it, but I think you use ATF or something to try and un-lock an engine. But if what you have told us true and the engine was run with no oil until it seized than use it as big boat anchor.
Old Jan 26, 2007 | 03:37 PM
ZeikHunter's Avatar
The Baxter
pull it apart and see how bad it is. might even be some bolts that are re-useable
Old Jan 26, 2007 | 03:47 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
You will have to pull it down to really know. If you are lucky only one "bearing" glued it's self to the eshaft if not you may not even be able to get it apart.
I would say the eshaft and and all "bearings" will be bad and need replaced.
Old Jan 26, 2007 | 04:03 PM
trochoid's Avatar
Old Fart Young at Heart
The 1st rebuild I ever did, it was a practice build, had no oil pressure, galled all 4 bearings and the e-shaft in 6 hours of run time in the shop, mostly at idle. The only thing that saved the rotors, irons and housings was the copious amounts of assembly lube I used.
You can pretty much plan on replaciing everything.. It will probably be easier to start with a completely different engine. A full tear down will tell, but don't count on finding much, if any, in the way of reuseable parts.
Old Jan 26, 2007 | 09:20 PM
Rx-7Doctor's Avatar
You are going to have 2 very important parts that are reusable. The front cover and the oil pan.
Old Jan 27, 2007 | 08:33 AM
diabolical1's Avatar
slap the previous owner with a used diaper.
Old Jan 27, 2007 | 11:57 AM
dr31283's Avatar
81rx-7
yeha its toasted i replaced my 12a last year with a rebuilt one from atkinsrotary.com it was 1600 plus i think about like 400 extra for the street port,but the extra 400 is worth it and if your serious about your rx get a new carb and intake from racingbeat.com
Old Jan 28, 2007 | 02:55 AM
RotaryEvolution's Avatar
Sharp Claws
i have had 2 engines so far that had loss of lubrication, both had little to no usable parts.
Machupicchu
Aug 17, 2015 08:27 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
