Rotary Drag Racing The place to post your racing stories and info
How Many have blew up a diff casing with a upgraded diff? on et streets
Old Jan 24, 2007 | 05:53 AM
showoff's Avatar
like the title says iam interested in how common it is to bust a diff casing while on et streets with an upgraded diff wether its a t2 diff or a kaaz..... did you use a diff brace or no?
-dj
Old Jan 24, 2007 | 12:43 PM
BLitzed33's Avatar
-dj
I broke my diff case in half with the common diff brace on and I was running a KAAZ LSD and DSS Axles...those were fine, but obviously my 4.33 gears were munched and this was all on ET Streets. I feel that if I didnt have the brace on there, it might not have broken, and maybe the ppf would have broken instead, I now do not run a diff brace anymore.
Old Jan 24, 2007 | 04:57 PM
showoff's Avatar
interesting way 2 look@ things.... may i ask wat were the conditions(tire pressure) and was it a str8 dump or slip?
-dj
Old Jan 25, 2007 | 03:39 PM
BLitzed33's Avatar
-dj
tire pressure was 14 lbs cold and it was a dump on the 2 step building about 7-8 lbs boost@6500 rpms
apooch
Sep 4, 2015 10:27 AM
tonka_1956
Sep 2, 2015 05:55 PM
