Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
13bt into s13
Old Jan 22, 2007 | 04:40 PM
rrw's Avatar
rrw
Rapidly Running Wild
13bt into s13
i am wondering if anyone has done a rotory into the s13..got links? i can get a real cheap s13 with a blown singlecam in it and the thought crossed my mind. i dont really like 240sxs but the deal is so good and i like rotorys...........
so what would it take as far as engine mounts, tranny mounts, could i get a custom drive shaft to go from t2 tranny into s13 rear end and how would i go about the gauge cluster?
Old Jan 22, 2007 | 06:10 PM
slo's Avatar
slo
registered user
Its been done, with both 13b's and 20b's. The gauge cluster is by far the least of your worries.
Old Jan 22, 2007 | 06:41 PM
rrw's Avatar
rrw
who did them? is there pics or anything?
Old Jan 22, 2007 | 07:07 PM
slo's Avatar
slo
registered user
search the other rotary section. It should be a very easy swap, at least space wise. If you don't have to worry about emissions legality maybe look at a 13b-re. But honestly with that much room under the hood, I would be looking at a V8, I think there is even off the shelf kits available for the V8, then there is allways the RB.
Old Jan 22, 2007 | 07:20 PM
rarson's Avatar
Yeah, V8's in the S13 have been done before. Personally, I would look at a swap that has been done before (ie, RB engine, SR engine, or V8) before even thinking about attempting the rotary swap.
Old Jan 23, 2007 | 06:07 PM
rrw's Avatar
rrw
but i like rotorys more and doing a swap that is common is boring.. im just gonna do it
Old Jan 23, 2007 | 08:51 PM
rarson's Avatar
Well go for it, but you'll need to remake the trans tunnel. The trans tunnel on the RX-7 is huge because the tranny sits kind of high... the "crank" is in the center of the engine, not the bottom.
Old Jan 23, 2007 | 09:30 PM
slo's Avatar
slo
registered user
I think you can do it without remaking the trans tunnel, the engine won't be as far back as it would in an rx7, it will probably still improve the balance vs a stock 240.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
BLUE TII
Sep 26, 2015 10:12 PM
