TII rotor on a GSL-SE 13b FI engine
Old Jan 21, 2007 | 12:16 PM
luism12lm's Avatar
Question TII rotor on a GSL-SE 13b FI engine
This is just a question. If I want to convert my GSL-SE 13B engine into turbo, is it possible to use a TII rotor on a GSL-SE 13b FI engine? If possible what else would I need? Where can I find more information?
Thank you,
Luism12lm
Old Jan 21, 2007 | 12:19 PM
trochoid's Avatar
Old Fart Young at Heart
Sure, you need the appropriate front and rear weights for the rotors you use, S4 or S5 and 2mm apex seals. You have a PM too.
Old Jan 21, 2007 | 04:04 PM
blazer1313's Avatar
Audio Cronic Syndrome
you'd need turbo end irons too unless for some reason you want to keep the wussy backpressure activated 6 ports...
actually there's no point trying to convert your 84-85 FI engine to turbo...1. you'd need an aftermarket ECU to be able to tune more fuel flow 2. the whole 6 port mess......mostly everyone just buys a JDM imported engine from a TII. Usually comes with engine, intake manifolds, injectors, wiring harness, turbo(s) and in some cases the transmission. In the 1st gen FAQ page there's a link to the whole TII swap How To
Old Jan 21, 2007 | 04:06 PM
stevensimon's Avatar
and one more thing.. keep the na rotors in the turbo motor! more power with less boost and a quicker spool. i love it to death. just make sure you have a good tune
Old Jan 21, 2007 | 04:09 PM
trochoid's Avatar
True, the 6-ports suck, but using 12A end irons during the build solves that problem.
Old Jan 21, 2007 | 04:46 PM
luism12lm's Avatar
Thank you guys, I’ve been doing some research and you all right. Sound like is better to swap instead of convert.
cdn
14
Sep 10, 2015 06:23 AM
ncds_fc
Aug 15, 2015 10:06 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
