How can I tell if my front bearing is gone??
Old Jan 18, 2007 | 05:07 AM
Bison Asko's Avatar
I recently did the thermal pellet mod on the ecentric shaft on my 86 s4 n/a. I did not push in the cluch like some of the threads said to do because I had not joined the forum yet. I pulled the front main pulley bolt by bumping the starter and using a long breaker bar to loosen the main bolt. I then shimed up the thermal pellet and put it back in with 60ft/lbs of torque. I have a shakey idle and i have checked for intake leaks and replaced the injectors also. The engine was tuned up about 3 weeks ago. The engine runs perfect and has good power. The rough idle is the only symptom, and it smooths out perfectly when i depress the gas a tad. I just wanted to know what are the signs of a sliped front bearing or a bad one.
Old Jan 18, 2007 | 08:43 AM
SomeGuy_sg's Avatar
http://www.mazdatrix.com/faq/pulley.htm
http://fc3spro.com/TECH/PROBLEMS/P1/...IDLE/rough.htm
Old Jan 18, 2007 | 08:48 AM
Aaron Cake's Avatar
Engine, Not Motor
If your front pully looks like this, then you have a problem:
Also, you will find little chunks of chewed up bearing in the oil pan.
Old Jan 18, 2007 | 08:57 AM
RX3SP's Avatar
Can't Hear Now
Check your end play. If you have no end play then the bearing dropped and got crushed.
Old Jan 18, 2007 | 08:58 AM
Bison Asko's Avatar
Thanks alot guys, I checked and all the belts line up properly. I am going to get a compression test done today just to eleminate the possibity that the engine is the problem. I have already searched and researched for a vacume leak and have found none. I have most of the emissions stuff blocked off. I used rtv black for the block off plates and also all new vacume lines for the rest of the ECU stuff. I just dont know whats going on. I did notice however the idle gets closer to normal with the BAC unplugged. And it does not stall when I turn the steering wheel or turn on any accessories with the BAC left unplugged. I just dont get it.
fidelity101
13
Aug 31, 2015 07:47 PM
GrossPolluter
Aug 15, 2015 10:32 PM
tallbozo
Aug 15, 2015 02:47 PM
