FI 12a
Old Jan 17, 2007 | 07:19 PM
speedrce1's Avatar
Question FI 12a
Is it possible to install fuel injection from a late '80's 13b NA onto a '84 12a NA motor using the intake and all the electronics and harness's??
Old Jan 17, 2007 | 07:23 PM
DriftFB's Avatar
Reno Rotary.
I know people have installed FI before, but I think that your thinking of the 84-85 Rx-7 thats fuel injected.
Search, you'll probably find something.
Old Jan 17, 2007 | 08:15 PM
rookie117's Avatar
why would you want to?
Old Jan 17, 2007 | 08:19 PM
speedrce1's Avatar
Why would you want a carb?? Carbs are a thing of the past. I like to keep modern with old engines, I FI my '49 Hudson flathead 6 cyl.
Old Jan 17, 2007 | 08:24 PM
rookie117's Avatar
i dunno, i guess i think carbs are more simple and easier on these older engines. to each is own though. id like to see pics of you get a 12a FI'd!
Old Jan 17, 2007 | 08:42 PM
trochoid's Avatar
Old Fart Young at Heart
Not really. The FC engines run 4 injectors, primaries in the center iron, secondaries in the LIM. Secondaries come on around 36/3800 rpm. Running the secondaries as primaries won't fuel the engine very effectively. If you changed out the center iron to an SE one, made a new intake system with a tps, afm, and related sensors, run the SE ecu, then it might be possible.
Old Jan 18, 2007 | 01:24 AM
woodonastick's Avatar
my fb is older than me
^with that said...i rather get a new carb...and with that said i wish i knew how to work with carbs too...
Andrew7dg
Aug 6, 2017 01:41 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
