CAS signal used by anything besides ECU?
Old Jan 14, 2007 | 11:48 AM
toplessFC3Sman's Avatar
Im in the process of changing around the wiring harnesses, cleaning stuff up, and preparing to run the car with a megasquirt. Is the crank angle sensor signal used by the tach, or anything else besides the ECU? will I need to route signal somewhere else?
Old Jan 14, 2007 | 11:50 AM
J-Rat's Avatar
Alcohol Fueled!
No, the tach signal is taken from the trailing coil pack.
Rat
Old Jan 14, 2007 | 12:02 PM
Ok, so cutting the connector plug for the tach off of the drivers side harness wont affect anything else (besides the engine/ecu, where i *think* i know what im doing)
Old Jan 14, 2007 | 03:03 PM
Aaron Cake's Avatar
Engine, Not Motor
When I do a standalone, I usually add another connector to the body harness in that area to make my connections to the trailing coil. That way you don't cut anything off the body harness or have to rewire the tach, and it keeps the harness in two parts (ie. no solder joints between the body and Megasquirt harness).
ZacMan
Sep 19, 2015 09:20 PM
nkuhajda
Sep 7, 2015 04:07 PM
