What's need to hook a 13B Rew to TII Transmission?
Old Jan 13, 2007 | 08:50 PM
Viking War Hammer's Avatar
*** Bless The USA
I know that I need to use a TII flywheel but what about the counterweight ?
Lupe
Old Jan 13, 2007 | 08:54 PM
NOPR's Avatar
Rotary Apprentice
you need to have an FD or S5 TII stock flywheel flywheel or counterweight.
Old Jan 13, 2007 | 09:43 PM
*** Bless The USA
So, with a 3rd gen motor and TII transmission. I can use a stock 3rd gen flywheel ? That's it?
Old Jan 13, 2007 | 10:51 PM
RotaryEvolution's Avatar
Sharp Claws
you need to elaborate a little better, it also depends on what car it is going into.
FDs have a pull type slave cylinder which won't work on a TII tranny unless you really start getting creative with the bellhousing(swapping it out but then there is the difference in the shifter mechanis/location and missing sensors on the TII tranny that are needed for the FD) or making a hybrid system.
Old Jan 14, 2007 | 06:19 AM
kabooski's Avatar
Laying Down Rotary Law
well I got a TII with a rew engine now
using the stock TT tranny
I just used my FC ACT extreme clutch kit on the FD wheel
as per my mechs instructions and everything bolted up nice
Old Jan 14, 2007 | 07:43 AM
hIGGI's Avatar
for TII transmission on REW
a) S5 TII flywheel/clutch
b) S5/FD automatic counterweight and some aftermarket flywheel/clutch combo suited for TII
pressure plate and clutch disc must match the transmission, flywheel/counterweight must match rotors (and S5 TII and FD rotors are same)
Old Jan 14, 2007 | 12:50 PM
kabooski's Avatar
Yes FD flywheel and a TII clutch
here is my new Half-Bridge/ Ported built REW motor with a TII front cover (work in progress)
Old Jan 14, 2007 | 05:08 PM
walken's Avatar
Registered Loser
[img]http://cfiracing.com/albums/album02/pic.jpg[/mg]
nice setup
custom or aftermarket mounts?
Old Jan 14, 2007 | 05:13 PM
staticguitar313's Avatar
R.I.P. Icemark
that is sexy, black and red... MMMMMMM
Old Jan 14, 2007 | 05:18 PM
kabooski's Avatar
http://www.motivefab.com/
makes them, good quality
It will look even better after I clean up the engine bay
and tighty everything up and install the rest of the setup
this was just a sneak peak of the mock up
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
