Sponsored by: CARiD
1990 Rx7 tranny problem
Old Jan 9, 2007 | 02:16 AM
daone's Avatar
I just bought a Rx-7 two days ago, the first one I have ever owned. Tonight I was going to go for a drive and after I turned the car on it would not go into gear. I turned the car off and tried to put it into gear and it worked. I then started the car and drove it and I could shift into gears. As I was driving the shifting became harder and then I was unable to shift into gears again. I turned the car off and I could put it into gear. I drove some more, shifting was fine then all the sudden it did it again. During all of this I hear a little squeeking and very little chatter. Does anyone know what this could be? I am thinking the throw out bearing. By the was the shifter seems to have alot of play in it also.
Thanks in advance for any help.
Old Jan 9, 2007 | 10:24 PM
KhanArtisT's Avatar
Former FC enthusiast
Clutch master or slave, check for leaking fluid. Pump the pedal really fast for like 2 minutes and see if that helps in shifting.
Old Jan 9, 2007 | 11:42 PM
daone's Avatar
thanks for the info
Old Jan 10, 2007 | 01:01 PM
daone's Avatar
I check the clutch master and slave and they are fine, no leaking. Could it be a pilot bearing or throwout bearing?
Old Jan 16, 2007 | 07:35 AM
wankelme!'s Avatar
ENGAGE LUDICROUS SPEED!!
pilot bearing would make horriffic noise as would throwout.Master cylinder leaks down the inside of firewall behind carpet and may not be noticeable,how's your fluid?have you tried bleeding?maybe have someone work the clutch while you watch the slave to see if it moves.Also you might pull the shifter and check that there is oil in the shifter housing,but 999 times out of a thousand its the clutch hydraulic system causing this
Old Jan 16, 2007 | 09:02 AM
gxl90rx7's Avatar
destroy, rebuild, repeat
Also, you may want to check your tranny fluid, it can get a little notchy if low on fluid or needs a fluid change
Th0m4s
Feb 26, 2019 02:04 AM
plentymoon
NW RX-7 Forum
Sep 5, 2015 08:55 AM
Wicked93gs
Aug 17, 2015 12:14 PM
Sharkbait24
Aug 12, 2015 10:36 AM
