Boost gaugeb reading
Old Mar 11, 2002 | 06:51 PM
My vac psi is 15 psi.. good or bad.. what is good range?
I removed air pump.. is that matter?
i think my vac used to be 16-17.... anyway.. 15 is good enough?
Old Mar 11, 2002 | 06:57 PM
nocab72's Avatar
03 Cobra Killer
15psi @ what RPM?
Old Mar 11, 2002 | 06:58 PM
idel
700-800 ish
Old Mar 11, 2002 | 06:59 PM
talking about vacume.. not boost..
mine is -15 psi..what is y'alls?
Old Mar 11, 2002 | 07:02 PM
nocab72's Avatar
03 Cobra Killer
I donno if that is good, or good enough, I just know that when I read other threads on idle vacuum the question was always asked what the idle RPM was when they were looking at the vacuum reading, figured I would at least help you get more helpful information out there so the pro's could toss in their 2cents.
K
Old Mar 11, 2002 | 07:03 PM
Thanks
Old Mar 11, 2002 | 07:12 PM
slipperyslater1's Avatar
I'm not one of the pros, but hear that 15 to 20, is good. Seems that would show overall good health of the system. Such as your vac. lines and all. A sudden change would indicate problems, and you would check accordingly. At idle, i show about 19lb. I may be wrong, and I've got a lot to learn, but I've had mine for about a year and a half now, and I've never had any trouble.
Old Mar 11, 2002 | 07:20 PM
mjw's Avatar
mjw
Idle vaccum readings are not measured in lbs/psi, that would indicate a positive reading.. ie. something under pressure. Vaccum is measured in Hg, the metric scale is something else.. can't think of it off the top of my head. I think 15Hg is a little low but it could be a lot of things other than bad compression.. vacuum leakage, gasket leakage, high idle, bad plugs, timing.. etc.
Matt
93 SSM
Old Mar 11, 2002 | 07:22 PM
okay thanks alot
Old Mar 11, 2002 | 07:35 PM
rynberg's Avatar
Vacuum is usually measured in inches of Hg (mercury), 15-20 could probably be considered normal for an FD, although 15 is a little on the low side.
Old Mar 11, 2002 | 10:09 PM
skunks's Avatar
I'm a CF and poop smith
when i first start my car my idle bounces and i get about 15-16 inhg and when my car warms up all the way, it is about 19.7 inhg. are you sure your not reading in inhg and not psi?
Old Mar 12, 2002 | 08:56 AM
high is good right?
today when i started the car hgmm was 15-16... and when car got warmed up it was 15..
Removing air pump matter? recently i removed air pump.
Thanks
Old Mar 12, 2002 | 10:27 AM
RedFD's Avatar
I got 25-27 last time i checked
Old Mar 12, 2002 | 10:35 AM
Mahjik's Avatar
Mr. Links
Originally posted by FstFD3SPOWER
high is good right?
Thanks
Removing the air pump shouldn't matter as long as you didn't knock something loose.
Is your engine stock or street ported? 12-15 would be normal for a street port. Non-ported should be around 16-19.
Idle should be about 16 - 18 in Hg.
Max boost should be about 10 PSI (for a stock car).
________________
Date: Thu, 29 Jun 2000 16:36:11 -0700 (PDT)
> My car idles at about 750 RPMs. Is the vacuum reading a sign of how
> aggressive the porting is?
Yes.
* Normal stock motor will show 18" or better.
* Mildly ported motors show 14"-16".
* Heavily ported motors can go down to 10"-12".
Old Mar 12, 2002 | 11:51 AM
rynberg's Avatar
I don't think it is possible to pull that much vacuum. Are you sure your gauge isn't marked in cm of Hg? 25-27cm would be 9-10 inches of vacuum.
Old Mar 12, 2002 | 12:29 PM
SanJoRX7's Avatar
uid 0
My newly installed Defi shows me at about 20 mmHg at idle. I have a pretty perfect boost pattern and the car runs fine, so I'm assuming that it's ok.
Old Mar 12, 2002 | 01:04 PM
Mahjik's Avatar
Mr. Links
Yep, mine hovers between 19 and 20. You should be fine.
Old Mar 12, 2002 | 07:42 PM
hehe.. mine isn;t ported yet..
but i get 16 vacuum.... ... ... .... .. .. ..
Old Mar 12, 2002 | 08:40 PM
Mahjik's Avatar
Mr. Links
Unless the gauge isn't reading properly, I'd say you have a problem.
Old Mar 12, 2002 | 08:42 PM
What kind of problem i might have?
Old Mar 12, 2002 | 09:29 PM
potatobbq's Avatar
a vacuum problem... that's the best answer anyone can give you since the only specifics you've given is you have somewhat low vacuum.
Old Mar 13, 2002 | 02:32 PM
Hmm.. .
Help? where should i look for??
hehe.. thanks
Hope my engine is okay..
Old Mar 13, 2002 | 03:32 PM
i god autometer gauge btw... are they accurate?
on my avc r it says 480mm/hg/.
Old Mar 13, 2002 | 03:37 PM
potatobbq's Avatar
If your Autometer boost gauge is saying 15 in of Hg and your AVC-R is reading 480 mm of Hg then one of them is off cause 15 in is not 480 mm. I would think the AVC-R is more accurate and 480 mm is probably more like 18 in of Hg so I wouldn't worry about it.
Old Mar 13, 2002 | 04:06 PM
RedFD's Avatar
Yeah your right..... I just went out and looked at my gauge and I dont know why i thought i got that much. Anyways I cant start my car right now so ill have to check up on it later.
