Just 2 quick questions.
Old Mar 11, 2002 | 03:35 PM
Supergrk21's Avatar
Suppose that I want to get an intake, a downpipe, a midpipe, a BOV, and a pulley kit. Would I need an ECU or something to provide more fuel? And also, is it a dumb idea to get a downpipe and midpipe without a cat-back?
Old Mar 11, 2002 | 03:39 PM
MastaCow's Avatar
yes.
Old Mar 11, 2002 | 05:29 PM
RecKleSs's Avatar
Adrenaline
You will definitely need to upgrade your ECU with all those mods. Here is a list of mods I suggest...
1) Intake
2) SS 3" Downpipe
3) A'pexi GT Spec Exhaust
4) Upgrade your ECU with Pettit's, PFC, or Haltech
5) Midpipe
6) upgrade your fuel pump and injectors
7) Pulleys.
Don't run more than 13psi without upgrading your fuel system and ic. If you still have the stock ECU you should only run 10psi.
Old Mar 11, 2002 | 06:28 PM
Zoomspeed's Avatar
1) Intake
2) SS 3" Downpipe
5) Midpipe
7) Pulleys.
Personally I would stick an IC in as #7. then pulleys at #8.
Old Mar 11, 2002 | 07:18 PM
Supergrk21's Avatar
Would it be a bad idea to just get a downpipe and midpipe without a catback?
Old Mar 11, 2002 | 07:20 PM
Supergrk21's Avatar
also, what is the cheapest ECU? if i didn't get an ECU, could i get something like the Apexi S-AFC instead?
Old Mar 11, 2002 | 07:43 PM
Zoomspeed's Avatar
I would say yes, because I think the main cat is the biggest restriciton in the exhaust.
You can find g-forces on partstrader for about 350-500, then you can usally sell your stock one for atleast 100. The AFC will allow you to fine tune the fuel, but you won't be able to do anything with the timing. A new AFC will also run you about as much as a used ECU.
Old Mar 11, 2002 | 07:57 PM
rynberg's Avatar
Why are you in such a big hurry to ditch the cat, is your's bad? Even though it seems like everybody has a midpipe, there are definitely cons to using one. (am now strapping flame suit on). Once you install a midpipe, you will probably have to port the wastegate to avoid boost creep. You should have downpipe, cat-back, intake, ecu, and probably intercooler and higher flowing fuel pump before adding a midpipe.
Coochas
44
Nov 5, 2019 11:08 PM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
