Water/Meth mixture inquiry
Old Jan 2, 2007 | 06:53 PM
Rotary4tw's Avatar
For the win...
[Current Setup] I currently have a coolingmist duel stage AI system in my 3rd gen, with two solenoids that control activation. One injector is larger then the other, and flows more. Injectors are mounted right after my intercooler about 12" from the throttle plates.
I have spent a lot of time reading this forum, as well as some of the other references posted in the stickies. I am still a little fuzzy on a few issues though, and am seeking clarity!
The initial purpose of the system was to inject water as a safety net from 12-15psi (each stage respectively) on pump gas, and the system would not be "tuned up".
When running straight water, albeit the power loss, I have been very happy with the results. I don't have an EGT, but my intake temps do drop under AI activation and part of me just feels good knowing that even at 13-15 pounds (which is probably very safe with my tune) additional heat is being soaked up adding another protection against detonation.
I know that adding straight water, as a general rule, will offer the greatest cooling effect of the AI mixes, while also reducing power. GooRoo performed some tests with his AI system on the dyno, one run without water, and then one run with water, with all over variables the same. With his GT-35r he lost 15hp at 9psi and about 20-25hp at 14-15psi. (Dropped from 390 to 365-370)
I know also know that adding methanol, as a general rule, will offer less cooling effect then water, but offer more power, because it is a fuel, and will burn with an octane rating of 118 or so.
Now, as an AI system user, who is not quite ready to "tune up"... I want to find a balance between water and methanol that will give me the benefits of cooling, but also minimize the hp loss from injecting a non-combustible agent such as water.
My question is the following:
Is there a mix of methanol and water that I can put into my AI system, that would provide detonation safeguards, but also not decrease the HP I would see if the AI system was inactive?
I'm curious if there is a mixture I can just dump on top of my map, which is a Kan tuned 11.5 across the range, which will not compromise power.
Would a 25/75 or 50/50 water/meth accomplish this?
I hope this makes sense.
Looking forward to next season!
-R4tw
Old Jan 2, 2007 | 07:16 PM
coolingmist's Avatar
Not all vehicles lose power from running 100% or methanol..Infact if you run 100% or 100% water your vehicle CAN lose power. Some vehicles have a computer that advances timing due to the colder temps and some gains are made. Either way...the biggest gains you can make are tuning your vehicle, but that leaves you with the problems of relying on the system.
you will hear alot of opinions and this thread will end up like all the others, but in my opinion nothing beats 100% water for detonation supression. When given a choice I prefer to run a 50/50 mix of methanol/water. i would run 100% water before I would run 100% methanol.
Probably not the answer you were looking for, but atleast my 3 and a 1/2 cents.
Old Jan 2, 2007 | 09:18 PM
RotaryEvolution's Avatar
Sharp Claws
i think the pissing contest is finally over.
i run a 50% methanol mix with 50% distilled water and i don't feel any real HP losses but you seem to get the best of both worlds however if you tune for the methanol and have inconsistencies it will be much worse than if your WI only fails. to me the benefits seem to outweigh the cons but it all depends if you trust your work and your AI system.
i did not take any numbers with the AI off and with it on but that is an interesting note that i am interested now in finding out if i am losing HP or gaining any with my setup.
Old Jan 2, 2007 | 09:56 PM
Sharp Claws
after re-reading i noticed you want to just add on an AI and not touch the tuned map is that correct?
if so you would be better off going with water as any mixture of methanol would need to be leaned out. unlike water it has to be burned or it will affect the AFRs and cause you to lose power if it is not retuned for the new mixtures. or if you can you could use the 50% mix and have the car retuned.
Old Jan 2, 2007 | 10:09 PM
Turblown's Avatar
Turn up the boost
R4tw,
Unless your intake temps are really high, I don't think you're going to be able to achieve what your asking without doing a retune. I know the area you're coming from, I can recommend a few people to help you readjust your maps. What efi system are you using? The power benefits of ANY form of AI need a retune, and a retune for that certain injection.
Rotary Performance Parts
Old Jan 2, 2007 | 10:20 PM
J-Rat's Avatar
Alcohol Fueled!
As I previously posted, water DOES cool better then meth OR alchy, hoever, you can inject MORE of the meth/alchy because its a fuel. Eventually you will be able to cool better because you are using more of the other injectant.
There are up sides an down sides to each method. If you are looking for a PURE knock suppresant, then water is your man (after all, it doesnt burn). If its cooling you are looking for, and you dont want power to suffer, then Alchy and meth are where its at. However, you do have to remove fuel in order to make use of the properties, and that is something some people dont care to do. The 50/50 mix seems to be the magic formula at the moment, although personally, I use 100% denatured.
Old Jan 2, 2007 | 10:22 PM
J-Rat's Avatar
Alcohol Fueled!
Originally Posted by coolingmist
Asking this question in this forum is inviting a pissing contest between various offenders.
Please keep in mind that, at least personally, I never came in on one side or another. My opinion is, you take the collective data and form your own opinion. Some will opt for water, others will opt for other mixes. The premise here is that we all work for a common goal, and not debase other ideas purely on personal preference. If I am one of the offenders you refer too, then you have my apologies for the said transgressions.
Old Jan 2, 2007 | 10:43 PM
Rotary4tw's Avatar
For the win...
Additional questions:
Not all vehicles lose power from running 100% or methanol. Infact if you run 100% or 100% water your vehicle CAN lose power. Some vehicles have a computer that advances timing due to the colder temps and some gains are made. Either way...the biggest gains you can make are tuning your vehicle, but that leaves you with the problems of relying on the system.
I am confident that with my system, all other things being equal, my car loses power when my AI is injecting straight water. I have felt this on the street, and after going through 3+ tanks of water at Road America. The amount of loss likely depends on how much it's injecting, at what PSI etc. (Assuming that the computer is not advancing timing due to air intake temps dropping like you said.) I'll try to post the dyno's from GooRoo's two runs when I find them again, and they confirm this. Again, this might not be with all cars, but it has been with both Rx-7's that I have seen that are running W.I. between the 330-400rwhp range.
At this point, I'm not willing to install a failsafe system and "tune up". Not yet anyways! My Rx6 turbo is too small, (Efficient until 18-19psi) the gains are too little (40hp tops?), and the risk is too big. (The last year of work for the whole setup). This will likely change in the future though.
Yes, at this point. Just trying to accomplish this without the HP loss from using straight water in my AI.
So, from what you are saying: (Correct me if I am wrong)
1) If I use 100% water, I will see horsepower losses.
2) If I use 50/50 water/meth, I will see horsepower losses due to the meth not being burned out, and richening the mixture.
3) If I use 100% meth, I would likely see horsepower losses do to the reasons in #2?
Seems like just dumping in meth in place of water won't really make any more power, unless you adjust the tuning. This would be easy enough to do, but if the system clogs, or is compromised, you find yourself running a map that is not safe and may be too lean without the aid of AI.
The conceptual problem I'm getting with all of this is the following. For the next example, I'm also assuming the following:
1) Each additional 1psi on my setup = about 10rwhp for my setup.
2) Running my W.I setup results in about 20-25 rwhp loss
3) Running W.I. will raise the level of safe boost you can run on pump gas by a factor of 3 or so pounds. (Based on general information I have read)
So now I have two scenarios, both which look very similar.
A) Run the car without A.I. at 15psi on pump gas and make 375hp.
or
B) Run the car with A.I. at 17psi on pump gas and make 375hp. (+25 from the extra 2 psi, and -25 from the water)
Conclusion: It may not be possible to achieve power gains with water injection, even if you turn the boost up, unless you tune up, or, if the boost added to the system exceeds that power loss from the water/meth.
I'm trying to find a way to do B, but without the power loss from the water.
I hope the above examples make sense, I know I am simplifying a lot of things that I don't fully understand, so feel free to point out where I may be off base.
Looking forward to replies!
-R4tw
EDIT: After reading through your replies, I think some of the main concepts are becoming clear to me. It takes me a while!
and
Makes sense to me now... just tossing meth in is just like tossing more gas in, richening the map cell if all things are left equal. (But cooling of course.) Same with water, except it's not fuel, it's just not burning.
Old Jan 2, 2007 | 10:52 PM
Sharp Claws
yep you pretty much nailed everything there but i believe you could push more than 3PSI safely but that depends on just how much water you are injecting. i really have no experience with water only so i can only speak from my experience with the 50% mix and i really haven't even gotten a chance to find out the limits of 50% yet until i get a new turbo that will be able to push that threshold. so far we have Peter who claimed something like 30PSI? safely on WI and Brian who made it to 24PSI on a 30% meth/70% premium pump mix and i have only really pushed up to about 19PSI on a 50%water/50% meth which makes up about 10% of my fuelling and far beyond the efficiency range of my tiny turbo.
on several occasions i was getting audible detonation at 18PSI on premium pump fuels ONLY and not due to faulty tuning so that is your starting threshold for pump fuel only and where you need to be weary of that line and crossing it without the support of AI will cost you a motor. it cost me more than one rear iron..
what we need is some unbiased rotary heads with water experience to chime in not someone who will turn it into a war of the worlds yet again.
Old Jan 2, 2007 | 11:18 PM
slo's Avatar
slo
registered user
If you adjust maps based on intake temps from a sensor located pased the water injection nozel, you should be able to take out some fuel and put in some timing based on the now lower injection temp. If the system fails the temps go up and timing and fuel go back to where tehy were.
Old Jan 3, 2007 | 08:39 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
i feel i have a sense of what can be accomplished w methanol and that is my project. i am intrigued w what a 50/50 mix can do. others will have to do the r&d.
just like you can jump way ahead on the learning curve if you are alcohol by going to the buick site where they have done it all already you can do the same for the 50/50 concept by visiting Snowperformance's site. they are 50/50 proponents and have nice stuff and a fairly active forum.
this is not meant to exclude other vendors who have experience w 50/50 but just a FWIW suggestion.
my compliments for the content in this thread.
howard coleman
Old Jan 3, 2007 | 09:24 AM
J-Rat's Avatar
Alcohol Fueled!
Lets take a look at one of the other points of debate; what happens if your system fails?
When removing fuel and substituting in a secondary injectant (alcohol), you assume a certain risk factor. Most systems have Low Level indicators and such, and there is even a fail safe system on others. However for the systems like mine, there is an element of risk. How signifigant? I would say no more signifigant then the chance of the fuel pump dying, or any MYRIAD of other things that could go wrong.
Now it stands to reason that if you are pushing the limits of 91 or 93 octane (depending on which state you reside), to 20+ PSI with water on top and THAT pump fails, then the damage will be no less severe.
Either system has limits and vunerabilities if you are operating them in extreme limits.
And as the old adage says "you get what you pay for". And that most certaintly rings true in this forum.
Rat
Old Jan 3, 2007 | 10:48 AM
sdminus's Avatar
Cant be bothered anymore
This might help ( if it works )
Scott
Tune 1 is with methanol. tune 2 is 50:50 on the same map
the only way you can be sure of anything is to do it yourself and take the internet with a pinch of salt
Attached Thumbnails Water/Meth mixture inquiry-5050.jpg
Old Jan 3, 2007 | 10:56 AM
sdminus's Avatar
or lean out a touch and i mean a touch and use water and this happens
Attached Thumbnails Water/Meth mixture inquiry-water.jpg
Old Jan 3, 2007 | 11:07 AM
J-Rat's Avatar
Alcohol Fueled!
Of course you lost power. You should have to lean out with 50/50.. Are those actual dyno runs?
Old Jan 3, 2007 | 11:22 AM
sdminus's Avatar
The base tune shows 318hp @ 6162rpm 305 tq @ 5032
These are not dyno runs but power runs from dataloglab. ( lots of people endorse it and i have verfied the readings on a dyno also for a good comparison. I have found it to be within 10hp at 300hp )
Scott
Old Jan 3, 2007 | 11:37 AM
J-Rat's Avatar
Alcohol Fueled!
I assumed "Benchmark" was straight fuel.. What were the variables used?
Old Jan 3, 2007 | 11:52 AM
scott,
it appears you used different smoothing factors? can you equalise?
howard
Old Jan 3, 2007 | 11:53 AM
sdminus's Avatar
The above runs are on 98 ron shell optimax and all on same fuel map and timing map
Methanol on the left
50:50 on right
I could display them all against basetune if needed
Basically the car had a rough map in so a added the differant chemicals to see what they did un-tuned. I then tuned them all to a point on the drag strip LOL
Scott
Old Jan 3, 2007 | 11:54 AM
sdminus's Avatar
they are all set up the same
Old Jan 3, 2007 | 12:22 PM
sdminus's Avatar
I dont know if this limited info is of anyuse to you but have a look anyway. If the info is deemed rubish then please feel free to remove the link
http://www.geocities.com/sdminus/ind...?1151874216342
Scott
Old Jan 3, 2007 | 12:49 PM
dis1's Avatar
www.silverbulletrx7.com
Scott
Rubish? I think not! Naturally results may vary but none the less this was very interesting. I'd be interested to learn more about the other mixtures you used. I have been leaning towards 50/50 or maybe 25meth/75water. Did you test that mixture by any chance? My tune is almost exactly like yours and I'll be adding AI without tuning for it.
Great post, don't remove it.
Old Jan 3, 2007 | 01:03 PM
scott,
i would appreciate it if you would post the entire body of your comparison so the section could see it. it is an excellently done series of tests.
howard
Old Jan 3, 2007 | 01:49 PM
BDC's Avatar
BDC
BDC Motorsports
Scott
That's not rubish at all. That is really cool, Scott!! I dig stuff like that.
B
Old Jan 3, 2007 | 02:54 PM
hondahater's Avatar
spending too much money..
Scott
this just confirms the reasons I want to go 50/50 mix. I know this was untuned but as you can see the 50/50 mix is really the best of both worlds.
