Vacuum is only Reading 12?
Old Dec 29, 2006 | 10:52 PM
crxturboh22's Avatar
Exclamation Vacuum is only Reading 12?
wasup yall my Vaccum is only reading 12khg whatever u call it.. so any ideas??
oh and Idle everything is Perfectly fine.. drivers fine nothing wrong..
check my Sign for my mods
so ....... i dunno..
my boost does fluctuate when i get on the gas.. so instead of 10 .. keeps going back and forth 8-10.... i dunno.. i searched about that and only thing i could think of was the actuator .. but dunno what to do..
and I have a AutoMeter boost gauge/Vaccum.
1st. - wasup with the VAccum
2nd. - y is my boost pulsing.
Old Dec 29, 2006 | 11:43 PM
ArmitageGVR4's Avatar
ArmitageFD3S
Sounds like a boost leak.
Old Dec 30, 2006 | 12:02 AM
????? boost leak @ full boost.. i mean throttle?... could that be??? BOV maybe??
Old Dec 30, 2006 | 01:22 AM
trainwreck517's Avatar
Rx-hippie
Could be a Vac leak, could be a tired engine, could be a bad gauge. First verify the gauge reading with a known good gauge. Then Check compression. Of other gauge reads 12inhg, and the compression is above 90psi on all faces..
Looks like you have you self a vac leak.. good luck on finding it.
Old Dec 30, 2006 | 08:18 AM
DaleClark's Avatar
RX-7 Bad Ass
If you're using that crappy nylon hose/brass ferrule setup that Autometer includes, it will leak if you disassemble and reassemble it more than once. Get a brass fitting that screws into the back of the gauge that has a hose barb, and run a proper vacuum line to the gauge to start with. Or get a better gauge...
Second, if you have the air pump on your car, make sure it's working. It's common for the insulation on the wiring going to the air pump to flake off, and the wires short to ground and blow the air pump fuse. It's the same as the AC fuse under the hood. With the air pump not running, vacuum will drop and idle and throttle response will be rough.
Check the easy things first .
Dale
Old Dec 30, 2006 | 01:50 PM
kyrx7's Avatar
what should the vacuum read at idle? in neutral
Old Dec 30, 2006 | 01:56 PM
silverTRD's Avatar
Time or Money, Pick one
on a healthy stock port motor, 17-19hg
Old Dec 30, 2006 | 02:00 PM
kyrx7's Avatar
how about a factory motor with down pipe mid pine catback, pfc, mine only at 15 when its in park(yes its a auto) but it seems to run strong. im gonna check the ac fuse under the hood. is it beside the battery?
Old Dec 30, 2006 | 03:39 PM
never mind my vaccum is fine its reading 16-18... my mistako
Old Dec 30, 2006 | 03:44 PM
my Boost still fluctuating... pulsing whatever the hell..
Old Dec 30, 2006 | 05:00 PM
White94RX's Avatar
BMW Tech
sounds like boost/vacuum leak.
my turbos are the poor man's nonsequential, I got the flapper door wired open. when it came off and the door was half open I got pulsating, not steady boost.
Old Dec 30, 2006 | 06:18 PM
JWteknix's Avatar
would vac read less on a ported motor?
Old Dec 30, 2006 | 10:46 PM
MR_Rick's Avatar
Planning my come back
just for info, vaccum reading will vary depending in altitude and weather. Vaccum reding is not a accurate way to see if you have a healthy motor.
Old Dec 31, 2006 | 06:58 AM
Sgtblue's Avatar
Urban Combat Vet
It will also vary with even small idle speed changes and operating temp of engine.
Old Dec 31, 2006 | 09:30 AM
DaveW's Avatar
Racecar - Formula 2000
Yes
Dave
Old Dec 31, 2006 | 09:49 AM
badddrx7's Avatar
All Spooled Up
Streetported motor vacuum runs around 14-15 in.
tom
Old Dec 31, 2006 | 09:52 AM
I see anywhere from 10 to 14 inches mercury on my heavily ported motor, depending on rpm.
Very low vacuum is an indication of a hurt motor, especially of the vacuum has a rhythmic fluctuation to it. Seeing 8 inches of vacuum at idle on a stock/streetported motor is never a good thing.
ZacMan
Sep 19, 2015 09:20 PM
t-von
Sep 10, 2015 01:56 PM
doritoloco
Sep 5, 2015 12:41 PM
Frisky Arab
Sep 4, 2015 06:17 PM
