Rotary Drag Racing The place to post your racing stories and info
3rd gen 2nd gear burn outs
Old Dec 27, 2006 | 09:35 PM
APEXL8T's Avatar
boxed in and drawn out
Any of you guys use 2nd gear? I have been doing 1st and came across other saying they have used 2nd. As long as tires are wet is it OK or does it shock load the hell out of the system?
Thanks
Old Dec 27, 2006 | 10:55 PM
Dan Schechter's Avatar
JIGSAWRX7
Thanks
What tires and size are you using? How much power are you making? As long as you have enough power to turn the size of tires you have, you will have no problem sith a 2nd gear burnout.
Old Dec 28, 2006 | 04:58 PM
streetdreamzny's Avatar
i've been doing 2nd gear burnouts with no problems for 3 years, also linelock helps
Old Dec 28, 2006 | 08:17 PM
APEXL8T's Avatar
Thanks for the response.
Well I havent dyno'd yet but 1st , 2nd are usless on the street and track .
I will say in the low to low mid 400 WHP?? when around 20 Psi
Let me say that with no 1st or much of second , into third short shift @14-15 Psi into 4th at 6400 RPM and get 8-10psi running mid rpms through the lights and I am hitting 116.5 mph( low profile 3 year old summitomo streets)
I am installing the 3 bar since my Sunoco came in this morning.So now I am going to use drag radials so I guess it comes down to if any of you guys do second with DR's. I know I need a line lock. Having the back jump out when the front gets set isnt cool ,when clutch dumping and brake . (no ABS) When doing a 2nd gear burn do you dump it harder are try too be smoother?
Old Dec 29, 2006 | 08:23 AM
Bacon's Avatar
IRS 4 Life
I let it rip in 2nd just like first, Usually if the water box is set up right you get enough water on them to get them spinning with ease, its also alot easier to maintain your rpms in 2nd, in first its usually an up/down thing. In 2nd you can lock your revs @ 6k wait till it starts to drop (tires warming up) then get out of it and stage like normal.
Old Dec 29, 2006 | 09:51 AM
APEXL8T's Avatar
Beautiful...Thanks!
Old Jan 2, 2007 | 10:47 PM
MichaelB145's Avatar
www.mancavecolorado.com
I learned the hard way by doing a 3rd gear burnout without a water box!
Old May 22, 2007 | 04:25 PM
13B-RX3's Avatar
7s before paint!!!
3rd, 4th, 5th, with water, without water, it all works for me. Just make sure the wheels are straight.
Old May 22, 2007 | 04:49 PM
crispeed's Avatar
'Tuna'
You better do your burnouts in 4th. When you think you can handle it and you're making some real power then you can graduate to 5th gear which is the one to use on your tranny anyway which is 1:1.
Bring that baby up to 7 or 8K rpm and let that clutch fly for the burnout.
I don't want to hear about any damm lame *** 2nd and 3rd gear burnouts with your setup.
I know you pretty much have the launch setup under control.
Next is to see if you can handle the ride all the way to the end!
Old May 22, 2007 | 11:15 PM
marcus219's Avatar
FC Mobsta
crispeed i totally respect your knowledge and experience but on almost all tranny's 4th gear is 1:1 5th is overdrive IE lower than 1:1 ......car to explain or did i read wrong
Old May 23, 2007 | 12:15 AM
crispeed's Avatar
'Tuna'
You read right but you misunderstood the facts. The tranny in Allen's RX-3 is not a factory Mazda one but a Dougnash where 5th gear is 1:1.
Anymore questions?
Old May 23, 2007 | 08:01 AM
marcus219's Avatar
FC Mobsta
welp.......no not really. im going to go ahead and go about my daily business of not trying to be completely retarded. hahahaha
Old May 24, 2007 | 01:32 PM
Doc Holiday's Avatar
Needs more cow bell
I could do 2nd gear burnouts with 8 inch slicks, and my car only dynoed 155rwhp on the motor.
Old Sep 9, 2007 | 09:58 AM
Chinsonder's Avatar
Newbie
The World Wide Web Virtual Pharmacy.
This website carisoprodol includes all the Pharmacy Related (loosely defined) Internet Resources that I know about. Please let me know if any of this information is out-of-date, incorrect, inappropriate, etc. I would be very happy to hear of other Pharmacy Related resources on the Internet.
Good site! Many thanks! This will be my first time visiting. Cheers!
Old Sep 10, 2007 | 05:57 PM
NewHotSearchHelp's Avatar
Newbie
The Search will automatically look for words with similar roots.
The search engine that helps you find exactly what you're looking for. Find the most relevant information, video, images. Please enter search criteria in one of the below fields. You can narrow your search to include publications by ticking the box next to "Search"-
wintergreen ground cover, kenyan clothing,
digital scramblers, stories of people losing their
virginity
, duster twister, tiny jap,
greek philosopher thales, false positive elisa,
saxon spanking stories, melanie beam,
raven mythology, kellar williams,
tiny loli, king air inflatable bed mattress,
hard erect nipples free, Using this Search page will not find information that is in the databases that make up a large part of the FDA Website. To perform a simple search, type one or more keywords in the Search Query box in the upper right-hand corner of the page and click GO. To limit your search, check the box next the following items you wish to include. This will include only those pets with the checked quali
fications.
mustanghammer
Race Car Tech
28
Nov 22, 2015 07:10 AM
thatfbtho
13
Aug 29, 2015 10:51 AM
rotor_veux
Aug 23, 2015 09:06 PM
pzr2
Aug 15, 2015 08:29 PM
Wolf_
Aug 11, 2015 04:23 PM
