HKS twin power, install ???
Old Dec 27, 2006 | 08:17 AM
joe1573's Avatar
NOPISTN
I am going to install my HKS w/harness tonight. Hook up seems easy but were do you put the unit itself? I've seen cars without cruise control mount ,but i have cruise. Is there room under or is there a better location? Any input would be appreciated, pictures would be great.
Thanks
Old Dec 27, 2006 | 09:02 AM
RE-Amemiya's Avatar
Not the company
(interested in seeing this as well)
Old Dec 27, 2006 | 09:18 AM
books's Avatar
Maybe not a good spot, but mine is on top of the brake booster behind the master cylinder. It is attached with double sided tape. It is a tight fit.
Old Dec 27, 2006 | 09:20 AM
chinaman's Avatar
Can you fit it near the igniter?
Old Dec 27, 2006 | 09:21 AM
DrunkenBowler's Avatar
https://www.rx7club.com/showthread.p...hks+twin+mount
Just some places to start.
As I recall, the hardest part about this mod is finding a location for this item to be mounted.
Old Dec 27, 2006 | 12:27 PM
RE-Amemiya's Avatar
Not the company
Thanks, tried searching but came up empty!
Old Dec 27, 2006 | 01:49 PM
I put mine on the left side firewall below the shock tower. their is even a hole drilled for it. makes it so easy. looks like it was ment to be there. also the twinpower is smog legal in california under CARB (California Air Resource Board) Executive Order # D-186-5 . for us California guys. We need all the help we can get (LOL).
Jeff
Old Dec 27, 2006 | 01:50 PM
rotarypower101's Avatar
sdrawkcab
This is how i placed mine
Fits well and detracts from that “look at all the neat toys” feeling
HTH
Old Dec 27, 2006 | 01:53 PM
VegasFD's Avatar
Wishin I Still Had The FD
^ I like that placement. It almost has an OEM look to it.
Old Dec 27, 2006 | 03:23 PM
joe1573's Avatar
NOPISTN
Thanks for all the input, lots of good ideas.
Old Dec 27, 2006 | 03:41 PM
1QWIK7's Avatar
White chicks > *
HTH
Damn your paint looks amazing, both body and engine bay!
Old Dec 27, 2006 | 04:18 PM
sdrawkcab
If only it wasn’t the trickery of an incredible camera and simple reality that it looked that nice!
Anyone in the greater Portland Oregon area want to hook me up with a competent painter at a reasonable price?
Old Dec 27, 2006 | 07:29 PM
Thumbs up twinpower
now thats how an engine bay should look.
Old Dec 30, 2006 | 02:05 PM
fc steve's Avatar
I havent seen on in person so im going to ask. Does the twin power run all ot the coils or just leading?
Old Dec 30, 2006 | 10:28 PM
NissanConvert's Avatar
Please somebody help!!!
IIRC the twin power is one of the only units that will run both properly. I could be mistaken.
Old Dec 31, 2006 | 09:25 AM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
It runs them all.
FWIW, I had mine on the driver's side rail. Of course, I didn't have A/C or PS or much else for that matter so it was very easy to get to. I do like that location next to the booster though. One thing I'd be concerned about is airflow and being able to properly cool the unit.
Old Dec 31, 2006 | 10:59 AM
7-sins's Avatar
thats not paint....
HTH
That does look smooth!! did you drill & tap a hole for it or is there one there?
Old Dec 31, 2006 | 12:03 PM
sdrawkcab
IIRC I used the washer fluid tube hole and reached in through the vent to hold the nut while screwing down the bolt, and relocated the line to the left of the pic.
Old Dec 31, 2006 | 12:17 PM
JDK's Avatar
JDK
Thanks
I mounted mine to the front of the car to let some air flow to it
Old Dec 31, 2006 | 12:34 PM
It never ceases to amaze me how *every* rx7 engine bay looks different.
Old Dec 31, 2006 | 08:38 PM
Trout2's Avatar
If you lift up the cruise control, there's room under there. I have mine zip-tied on top of the fuel pump resistor since the hole on my shock tower was already taken for an oil catch can.
Jack
streetlegal?
Mar 17, 2022 02:46 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
