Does a 1988 rx7 turbo II tranny fit a 1993 twinturbo rx7?
Old Dec 21, 2006 | 07:01 PM
rx_08's Avatar
Newbie
Does a 88 rx7 turbo II tranny fit a 93 twinturbo rx7?????????
Old Dec 21, 2006 | 07:29 PM
dgeesaman's Avatar
Yes, but you might need to get an FD endhousing or something to mate up to the PPF. I know KD sells FD trannys done with T2 internal parts.
Dave
Old Dec 21, 2006 | 10:42 PM
bheiman's Avatar
hum, will the fd bellhousing and the turbo 2 bellhousing interchange?
i had a turbo 2 tranny right next to my fd tranny for about a week and looked at it, but not close enough
they didnt seem any longer though
kinda interesting i might experiment soon enough
Old Dec 21, 2006 | 10:45 PM
RotaryEvolution's Avatar
Sharp Claws
what seems to be the real benefit?
i have already replaced 2nd and 5th gear syncros in T2 trannies for the same reason they fail in the FD trannies.
Old Dec 22, 2006 | 02:22 AM
dgeesaman's Avatar
I think the biggest difference is the FD has double-cone synchros for 2nd and 3rd, while the T2 has single cone synchros all around.
I suppose the biggest reason is the T2 is mechanically similar.
I suspect the bellhousings don't need to swap since the rear housing is the same on a T2 and FD. (Or maybe not - I'm not an engine rebuilder)
Dave
Old Dec 22, 2006 | 06:38 AM
Busted7's Avatar
Will work for horsepower
I belive you need to address the push verses pull style clutch! Plus mabye the starter location depth etc. I would guess at the least the bell houseing would have to be replaced.
Old Dec 22, 2006 | 08:56 AM
rx_08's Avatar
Newbie
so the t2 tranny would fit the FD right?
Old Dec 22, 2006 | 09:27 AM
Lightbulb
did you read the replies to your initial post or not?
I recommend you install an FD tranny into an FD. Makes a lot of sense.
Old Dec 22, 2006 | 09:43 AM
ultmtrx8's Avatar
^ +1
Old Dec 22, 2006 | 01:28 PM
DaleClark's Avatar
RX-7 Bad Ass
The guts of the trannies are basically the same, but you're looking at doing some component swapping and pioneering to make it work, and there's a lot you could screw up.
I wouldn't bother. Sell the TII tranny to finance an FD tranny. You can get good used FD trannies for a pretty reasonable price.
Dale
Old Dec 22, 2006 | 02:32 PM
jd to rescue's Avatar
Well, as long as someone started this thread . . .
If you have an FD tranny to scavange from, you should be able to see fairly quickly. At a minimum, you will need to swap the bell housing and the end housing. The bell housing is needed for the pull-type clutch on the FD (vs. push-type on FC). The rear housing will need to be swapped for the PPF. The interesting question is how the FD shifter and bushings will line-up with the internal rods on the T2? They would not necessarily be any different.
Old Dec 22, 2006 | 07:58 PM
Sharp Claws
the main section of both trannies looks identical from my perspective, i rebuilt both an FD and an FC tranny in the following week and the main body looked almost identical but i didn't have them both apart at the same time to notice any of the differences. the shifter forks are all located in the same spot and the output shaft looked identical from memory.
Old Dec 22, 2006 | 10:58 PM
dgeesaman's Avatar
I know Dave at KD has been doing this for some years. I don't know the specifics why, but surely there is a reason. My impression, like Karack suggested, is that they do pretty much bolt together. Perhaps a different bearing or two are required, but that's just off-the-shelf stuff.
Dave
autoxer
21
May 22, 2019 04:07 PM
Kyo
Apr 13, 2019 09:24 AM
Icearia
13
Feb 21, 2016 09:18 AM
NJ-JDM
43
Aug 23, 2015 11:02 PM
