Pilot bearing puller
Old Dec 21, 2006 | 06:54 PM
palsor1's Avatar
Hey guys,
I just thought I'd throw this tidbit up here... The loaner tool they have at Advance Auto Parts worked perfectly for taking out the pilot bearing, and even better it was free .
- Andy
Old Dec 21, 2006 | 07:10 PM
DigDug's Avatar
Registered User
I've used that one too. I had to grind down the "fingers" a bit to get it to fit, but it was pretty close. The tool might vary a little from region to region.
Old Dec 21, 2006 | 07:53 PM
poss's Avatar
Slower Traffic Keep Right
The "blind hole puller" from autozone works like a charm too.
Old Dec 21, 2006 | 08:39 PM
Jimbo Sage's Avatar
Anyone try filling the pilot bearing with grease, then taking a dowel rod the size of the opening and hitting it with a hammer. The grease should push the pilot bearing out.
Old Dec 21, 2006 | 10:49 PM
RotaryEvolution's Avatar
Sharp Claws
messy but does work.
i prefer just using the loaner tool to save the mess, worked well enough that i didn't return it.
Old Dec 21, 2006 | 11:43 PM
bladz311's Avatar
I've used the advance one before... broke 3 of them, lol. I ended up getting the atkins rotary one. It works great! I use it pretty often at my shop, even works for dowel pins if you unthread the pilot bearing atachment! IMO, the atkins one is totally worth the one hundred whatever it costs.
ls1swap
Jun 3, 2024 03:25 PM
Vartok
16
Oct 8, 2015 04:49 PM
