I don't know where the fuel pump relay is at.
Old Dec 20, 2006 | 01:26 PM
MavrickFD's Avatar
Soory if this is a noobie question, but where is it?
Old Dec 20, 2006 | 01:41 PM
Veger's Avatar
Its in the fuze/relay box under the bonnet near the rad/intercooler.
Right at the front of the car.
Old Dec 21, 2006 | 09:51 AM
mad_7tist's Avatar
that is only the speed control relay. the power relay is next to the battery
Old Dec 21, 2006 | 09:54 AM
dubulup's Avatar
development
the one in front...of the two in the side box
labeled AI relay in this pic
never mind the labels, I don't use the stock FP wiring circuit for the fuel pump
Old Dec 21, 2006 | 11:08 AM
Ehron's Avatar
Originally Posted by DaleClark
Pull the upper intake manifold and pressurize the fuel system by jumpering the FP connector in the diagnostic box. You seriously need to find that leak!
Dale
So is the part you circled where I would do what Dale suggested above to pressurize the fuel system?
Old Dec 21, 2006 | 11:19 AM
jd to rescue's Avatar
If you are checking for a fuel leak or just want to pressurize the fuel system, you do not do anything with the fuel pump relay. Go to the "diagnosis" box at the driver's side fender and jumper the contacts that correspond to "fuel pump" and "ground". Look inside the cover of the diagnosis box to see which is which. Once you make the jumper connection turn the ignition switch to the "on" position (do not start the car). You should then hear the moan of the fuel pump working. All of this is also in the shop manual.
EDIT: A paperclip works perfect to jumper the contacts.
Old Dec 21, 2006 | 11:28 AM
pinkrx7's Avatar
fadedvr=pink
ten + gnd
Old Dec 21, 2006 | 09:48 PM
Ehron's Avatar
Thanks guys. I downloaded the service manual, but hadn't had a chance to look through it.
Old Dec 21, 2006 | 11:22 PM
cewrx7r1's Avatar
Eye In The Sky
Download the manual and lean your car.
Old Feb 21, 2007 | 07:18 PM
dream77's Avatar
lean it?
Old Feb 21, 2007 | 07:33 PM
mad_7tist's Avatar
holy thread diging batman
seriously there has to be a statute of limitations for the spelling/usage *****
Old Feb 21, 2007 | 08:33 PM
dream77's Avatar
lmfao
Old Feb 21, 2007 | 08:38 PM
dream77's Avatar
man i just laughed so hard my eyes watered.
thank you.
ok.
i admit it, ive been thread digging. and searching. but with reason.
i am a n00b (obviously) and i am in the midst of a FPD replacement. Once I got in there I saw that my primary injectors were leaking as well.
I have access to an equally old set, but i think that if I get them installed that they will leak too.
So, long story short, I am thinking of buying new injectors and then installing those.... BUT
on the O-rings on the injectors, should I wipe a bit of lithium grease on them?
Or leave them dry when I replace them////
I already wiped some grease on the new FPD's o-ring, installed that, and then tested it for maybe 2 min like this:
https://www.rx7club.com/showpost.php...&postcount=255
It didn't leak. The primaries I had in there at that time sure did though.
Old Feb 22, 2007 | 01:17 PM
dream77's Avatar
bump ! heeeelp pls ! god knows i dont want to put this UIM back together and find out that its still leaking.
I would love it if someone would tell me if the o-rings go in dry or greased or what.
PLz !
Old Feb 22, 2007 | 01:39 PM
dubulup's Avatar
development
vasoline...I'm sure lithium is fine as well.
any o-ring should be lubed upon installation
Old Feb 22, 2007 | 01:47 PM
Mahjik's Avatar
Mr. Links
For the fuel system o-rings, I use MMO (Marvel Mystery Oil). They should not go in dry.
Old Feb 22, 2007 | 08:29 PM
dream77's Avatar
Thank you !
By the way,
This worked perfectly!
Queppa
Nov 18, 2024 03:47 AM
