Sponsored by: CARiD
OMP question
Old Dec 11, 2006 | 11:40 AM
djmtsu's Avatar
DGRRX
OMP question
Going Standalone...Simple questions:
Should I get a standalone that can run the S5 OMP?
Should I ditch it and pre-mix (PITA)?
Should I get an S4 front cover and mech OMP?
Which is the BEST option? Please give reasons!!
Thanks guys!
DJ
Old Dec 11, 2006 | 11:55 AM
R_PROWESS's Avatar
F[x]3S ENG.
ull get many diffrent answers with questions like that.. i prefer premix
Old Dec 11, 2006 | 01:04 PM
djmtsu's Avatar
DGRRX
All the local guys say pre-mix as well, but I was thinking of other options. I drive my FC as much as possible and don't want to get stuck without oil.
Was kinda thinking what the general consensus is.
Old Dec 11, 2006 | 06:09 PM
diabolical1's Avatar
order of my preference:
1. premix
2. mechanical OMP (refurbished or modified)
3. electronic control
Old Dec 11, 2006 | 06:45 PM
have you seen THIS yet?
Old Dec 11, 2006 | 07:11 PM
djmtsu's Avatar
DGRRX
Dude that is so funny because I just got done reading it.
Thats freakish.
I am still trying to decide what I want to do. I might just slap on an S4 front cover and what not and call it a day.
Old Dec 14, 2006 | 05:02 AM
cr6zed's Avatar
Premix is the best option if you want engine life. Premix is 'clean' oil as opposed to the crap that is recirculated from your sump. I had an idea to put an in-line fuel line oil feeder somewhere on the fuel line to premix for you, like those gernies/high pressure hoses that premix carwash and stuff. Need to research how they work though and hook up a brass setup to mimic such a hair-brained idea.
s4 front probably the easiest way to do it, but not accurate, as the lever that controls the OMP is controlled by the throttle (mechanical). At least with premix, you know you are getting exactly 100/1 or whatever you have been told to mix it.
Old Dec 14, 2006 | 05:08 AM
cr6zed's Avatar
Even if you get a s4 front housing and you don't like it, then just disconnect the mech. lever from your throttle and run premix. Then you have two of your three options. I don't know much about your third option (stand-alone oil feed). I guess you are getting clean oil, but the cost of an oil pump and a resevoir to hold the oil is probably the most expensive way.
Old Dec 15, 2006 | 08:46 PM
Tramposo's Avatar
Always on boost!!
I went premix for a while and got real sick of it real quick. So, I opted to install a OMP adapter and adjuster that pulls clean 2 stroke oil from a external reservoir. This also allowed me retain my S5 front cover.
But as you can see you have several options.
Old Dec 16, 2006 | 03:31 PM
cr6zed's Avatar
Adapter??? sounds workable. Where would one find one of these...Adapters?
Old Dec 16, 2006 | 06:56 PM
AHarada's Avatar
rotaryaviation.com
Do a search for adapter and the adapter and adjuster will show up.
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
rotor_veux
Sep 3, 2015 07:10 PM
