New tereo Install 56k be scared!
Old Dec 7, 2006 | 06:25 PM
John64's Avatar
What?
Well, many of you have seen my old system and I really like it, but I was bit by the stereo bug and I'm redoing it.
Here are some pics of the old system:
Here its is now:
I use to run all my speakers off the headunit, but I'm upgrading to a badass Alpine 4 channel so I ran all new speaker wires to the rear (kick panels, doors and rears). As you can see it takes alllot of wires to make a system like this happen.
The start of the sub box:
Dry fit of the side panels:
I will be doing a complete fiberglass top to this and have a real nice design in mind. I will be updating everyone as I go along. I hope I can help others at the same time. I should have the basics of the sub box done tomorrow and hopefully some fiberglassing Saturday.
John
Old Dec 7, 2006 | 08:23 PM
RE-Amemiya's Avatar
Not the company
Looks like a good start!
Old Dec 8, 2006 | 03:20 PM
John64's Avatar
What?
Update today:
Started gluing it together
1/2" chuck with a 1/4" rabbiting bit.
Do this all around the box, so when you put your fleece on to fiberglass it will have something to staple to and an easy transition to the box edge.
Positioning the sub:
Hot glued dowels in place once the positon is just right!
Finished position and the basic cutout of the back of the box.
Box placed in it's new home:
Next step is some internal bracing then the fleecing!
Old Dec 10, 2006 | 04:49 PM
John64's Avatar
What?
I did not get as much done this weekend as I would have hope for, it was damn cold.
Put in the perminent internal bracing:
I stretched the fleece and used an electric stapler to staple it around. This is why I did that 1/4" rabbit all the way around the box. Now all the material will come up flush to the edge of the wood.
You can see the shape now!
I managed to get to coats of the fiberglass resin onto the fleece material before it got dark:
I'm going to let it harden over night then get a good coat of resin on the interrior edges and seams to seal it up real nice. Next step after that is 5 layers of fiberglass mat and then a nice coat of resin and cabosol mix on the interrior to realy thicken things up.
Old Dec 11, 2006 | 02:43 PM
John64's Avatar
What?
Well today was a good day. I got 3 coats of mat fiberglass down and it's setting real nice. A couple more then some interrior box work with some cabosol.
I had to make a base plate for the box since the shock mounting plate hump up about 1/4" on each side.
Here she is in her new home:
It will still need alot of sanding then a nice coat of body filler, with more sanding.
I'm taking this Friday off, so I hope to have it up and running by then.
Old Dec 14, 2006 | 03:51 PM
John64's Avatar
What?
Ok, I was busy and has no chance to post pics, but here they are.
Finished the wiring for the amps (lots of wires)
The relays at the bottom are for so little neon tubes under the amps!
Alpine MRV 303 for the fronts and rears. 60x4
Alpine MRV 1507 Bridged 1000x1 (thats max at 12.5 volts, so constant at 14.4!)
Like I said, lots of wires!
Heres the update on the sub:
Sanded, bondoed, sanded, bondoed and sanded one last time! Ity's ready to get carpeted and installed.
I tested the amps and everything is up and running. I'm on the home streatch, I took off of work tomorrow, so I should get this thing buttoned up except for maybe the trim panels.
Old Dec 15, 2006 | 09:57 AM
DC13B's Avatar
new paint
not bad, how many watts? u running to it? my s-10 has two 12s and 2000watts. hits 153db
Old Dec 15, 2006 | 11:38 AM
John64's Avatar
What?
Read the above captions. Around a 1000 to the sub.
Old Dec 15, 2006 | 11:44 AM
John64's Avatar
What?
Well, did some work today.
I wanted to add some sort of flair to the box and this is what I came up with:
Its actual size as I took out one of the rotors I have laying around and did a little tracing.
Box carpeted (Yes it was a pain in the ***!)
Got it installed:
Well it sounds real nice, just need to do some adjusting!
Now the hard past of trimming it out.
[img]
Old Dec 15, 2006 | 12:23 PM
challer2000's Avatar
Ask me about my wankel
Wow that looks great! I really like the rotor design on the box it adds a lot to it.
Old Dec 15, 2006 | 02:36 PM
REVolutionaryRotary's Avatar
That's pretty cool. Congrats on a unique setup.
Old Dec 15, 2006 | 03:45 PM
John64's Avatar
What?
Thanks guys!
Old Dec 17, 2006 | 07:47 PM
HardHitter's Avatar
Very nice, looks like my box for my FD that I made
Question is, how does it sound?
Old Dec 19, 2006 | 03:28 PM
93FD3S's Avatar
Big Snail
HardHitter ..............
Nice box. Let me know if you ever wanna make another one or get rid of that one.
Old Dec 19, 2006 | 04:26 PM
gonzz's Avatar
Nice work..
Old Dec 20, 2006 | 09:51 PM
BenJaRank's Avatar
Old Dec 20, 2006 | 10:22 PM
mirabile's Avatar
i like both boxes. Then again...I love box.
Old Dec 21, 2006 | 02:52 PM
John64's Avatar
What?
Well guys, I just finally finished to trim for the amps:
Old Dec 23, 2006 | 03:54 PM
John64's Avatar
What?
Tell me what yah think!
Old Dec 23, 2006 | 04:31 PM
cabaynes's Avatar
Old and grumpy
I don't really see the point of stereo's in sports cars, but i do admire your craftsmanship! You did a really nice job, and I like the rotor shape and rx7 emblems, very professional! I'm glad it blends nicely and isn't some crazy painted fiberglass with neon lights everywhere
Old Dec 24, 2006 | 01:28 AM
deagle50ae's Avatar
great work! very clean install.
check out fiberglassforums.com if you want to. great bunch of guys over there that are all crazy for glassing.
Old Dec 24, 2006 | 03:10 AM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
i hate you...lol i will soon finish mine but work is keeping me i actually have been sleeping over at work a couple nights in a row.....wait i hear john saying- bah stop ur excuses lol
Old Dec 24, 2006 | 02:42 PM
deagle50ae's Avatar
I need a heated garage... im dying to start some new fiberglass work! I haven't even finished my console yet... to friggin cold.
Old Dec 24, 2006 | 03:58 PM
John64's Avatar
What?
My garage is not heated, but it's just been so damn warm for this time of year. It's been like 52 and it's Christmas!
Old Dec 24, 2006 | 08:29 PM
staticguitar313's Avatar
R.I.P. Icemark
very nice work, how did you do the raised rotor and text?
