Microtech Any suggestions? Lt8s 13b RE
Old Dec 6, 2006 | 09:25 PM
Michaelangelofb's Avatar
Ijust put a street ported rebuilt 13b RE in a Second gen with a lt8 s. If someone has any tricks or suggestions I would appreciate a pm. I am running stock boost on efini turbos.
Old Dec 21, 2006 | 12:50 AM
thinkpad1260's Avatar
13b-re microtech
hi i'm in quebec , so i have this engine 13b-re with a microtech lt8s .My setup is running verygood , I have a super hybryde t61 with secondary injector 1600CC, i have alsoa walbro fuelpump and stock fuelrail . So i pass on a dynapack butprobleme with Catalizer , so i remove the cat and when i remove, the car running very well .When i have money to go another time on th dyno a give it to you, the details . ciao and good luck
felix
Old Dec 23, 2006 | 01:16 AM
ding_fries_area_done's Avatar
cant run 1600cc with stock fuel rail,
Old Dec 23, 2006 | 02:48 AM
RotaryEvolution's Avatar
Sharp Claws
yes you can, and why don't you get a real hobby instead of sitting on your *** making fake names to hide behind on the intranet.
Old Dec 23, 2006 | 10:00 AM
Aaron Cake's Avatar
Engine, Not Motor
There's nothing really different about the RE. One thing to check is to make sure the stock temperature sensors are reading the same values as the FC sensors, but I'm fairly sure they're the same.
Old Dec 23, 2006 | 06:15 PM
Yeah true that!!! Fake names are stupid and you can use 1600 cc with stock rails thanks for the help guys and keep it coming if you have anymore !!!
Old Dec 27, 2006 | 05:19 PM
Jon Goodwin's Avatar
Running a 13b-RE in an FC, making 430atw @0.91bar. Lt8
Old Jan 24, 2007 | 01:23 AM
vinnieccr's Avatar
im trying to run a re in a fd using the angle crank senors. But it still doesnt start it cranks but the timing is off and it back fires few second.the maps are fd3s.I know most likely no one going to give me any advice or hints on what should be done. but o well.
Old Jan 24, 2007 | 01:22 PM
Aaron Cake's Avatar
Engine, Not Motor
If you are using a Microtech that was originally for the FD, then it cannot read the FC CAS. You need to send it back to Microtech to be configured for the CAS.
Old Jan 24, 2007 | 04:15 PM
You can use the REW front cover with pump, pulleys etc.
Old Jan 25, 2007 | 01:22 AM
vinnieccr's Avatar
already did that. front cover and pulleys. everything for the rew is put on there. thank alot for responding i didnt think anyone would.
Old Jan 25, 2007 | 02:04 AM
slo's Avatar
slo
registered user
if your using the rew front cover why not use the rew ign pickup?
Old Jan 25, 2007 | 04:07 AM
That is what I'm suggesting, and will work if setup properly
Old Jan 28, 2007 | 02:24 PM
vinnieccr's Avatar
thanks again guys by trying to help me get ideas to the problem. what i get is that i put everything rew. the onlt thing re is the block now. im starting to think that its the timing pulley position wrong.
Old Jan 29, 2007 | 05:30 PM
rx72c's Avatar
Top Answer: 1
The shaft is your problem.
Timing on s6 shaft is different to cosmo.
Should have also put the s6 shaft in it.
Old Jan 30, 2007 | 09:59 PM
vinnieccr's Avatar
its a low miles motor. I thought i could save cost by getting the re, but I guess not. I just wonder if anyone have did the re swap in an fd. But ill most likely put the motor out and just rebuild it and change the shaft.
Old May 10, 2007 | 05:15 PM
puzzlerok's Avatar
What about if it's an S5? Is the timing of the S5 shaft different from the S6?
Lou Byer
20
Oct 12, 2020 08:03 PM
