Sponsored by: CARiD
Primaries and secondaries in same rail?
Old Dec 1, 2006 | 03:26 PM
ScuttleRX's Avatar
Can you run all the injectors in the same rail?
Was looking at the Xcessive LIM with its 4 injector ports and wondered if you located all the injectors there whether you'd still need 2 rails or just run them all off one?
Old Dec 1, 2006 | 10:38 PM
Rocking Rotary's Avatar
you would need a rail with four ports if you want to run all the injectors. You still need to run you primarys though in the stock position.
Old Dec 1, 2006 | 10:46 PM
diabolical1's Avatar
when it all comes down to it, the injectors all have to have individual electrical inputs to fire, so i don't see why you couldn't run all on a single rail as long as pressures remain adequate.
Old Dec 1, 2006 | 10:57 PM
ScuttleRX's Avatar
Cheers chaps, yeah I meant a new rail with 4 ports. The pressure thing was what I wasnt sure of, not sure if there would be a pressure drop when the secondaries come online?
So you cant move the primaries then...will knock that idea on the head, whats the reason for this, not arguing just curious
Old Dec 1, 2006 | 11:53 PM
If you want it to start quick and reliabliy leave them were they are. The Secondary ports are along ways back and the fuel distrobution will promote flooding if you use them as primarys.
ls1swap
Jun 3, 2024 03:25 PM
eplusz
15
Oct 7, 2015 04:04 PM
