South RX-7 Forum Serving Texas, Oklahoma, Arkansas, Louisiana, Mississippi
Anyone have a Bearing Press for Stationarys and Rotor.
Old Nov 24, 2006 | 09:47 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
I will be changing all my bearing in my up comming rebuild and will need thows special bearing presses and i dont want to spend 100+ dollars to buy two of these just for this rebuild.
I would like to use them or do it at your place, witch ever is better,
Does Maz Max have the abily to do this?
Old Nov 24, 2006 | 09:53 PM
DrKillJoY's Avatar
Administrator
Not sure if Maz-Max can or not... give them a call tomorrow - 713-896-8005. If they can't do them, Bryan should be able to tell you where to go.
Old Nov 25, 2006 | 08:52 AM
twokrx7's Avatar
Need more sleep
Just ship your parts to Rotorsports Racing and have them press in the new bearings. You will need to mic the e-shaft journals so they can clearance the bearings appropriately.
ls1swap
Jun 3, 2024 03:25 PM
Vartok
16
Oct 8, 2015 04:49 PM
