FD wheel fitment +35 offset
Old Nov 22, 2006 | 11:31 PM
eli_eli's Avatar
hi guys, i already searched and went over the FD fitment thread but hope you guys dont mind if i confirm this.. going for a semi-conservative set up..
18x8+35 F 245/35
18x9+35 R 265/35
this should clear no probs on stock body FD right? from my calculations i could possibly run 15mm spacer if needed to bring them out just a tad to match tire racks suggested offsets..
18x8.5+32, 18x9.5+32 if i'm not mistaken.
Many tks in advance!
Old Nov 23, 2006 | 12:56 AM
Black91n/a's Avatar
I'm no FD wheel expert, so I don't know for sure if they'll fit or not, but the stock offset is 50, those are already 15mm further out, so adding a 15mm spacer will only make matters worse. I think the offsets are probably too low, you need to try to get offsets closer to 50mm.
Old Nov 23, 2006 | 08:07 AM
turbogarrett's Avatar
0 lbs of boost
Those should fit fine.
Old Nov 23, 2006 | 11:58 AM
purerx7's Avatar
Registered User
should be fine, but you may need to roll the fender a little bit, I have +38 all around and have no rubbing or any problems.
Old Nov 23, 2006 | 01:07 PM
rynberg's Avatar
Eh, they'll fit but it's certainly not ideal. And a spacer LOWERS the offset, not raises it!
Running a 245/35 18 on a 8" wide wheel is not recommended. You are going to have to run a 225/40 or 235/40.
Old Nov 23, 2006 | 05:00 PM
eli_eli's Avatar
tks for the replies guys! i knew the front may have been little too wide but my second choice in line was 235/40 that is widely available.. so probably this is what i'm going to end up with.. and 265 in the rears.. i hope it all fits nicely.. so with the specs of the wheel i listed, you guys would not consider this conservative?
btw i made an error when checking with tire rack.. their suggestion is
18x8.5+38 235/40
18x9.5+38 265/35
so i'm hoping its all going to work out perfect!!! i'll run that 235 on an 8 with a tad lower offset.. but should come out the same with a little smaller wheel and same applies for the rear.. if you guys look at my first post i had my specs wrong from the tirerack so thats why i mentioned 15 spacer that i may need.. but definitely wont be needed now that i cross checked again! will post pics as soon as these babies are on, you guys are goona like it! thats a promise!!!! stay tuned!!!
Old Nov 23, 2006 | 07:48 PM
Mahjik's Avatar
Mr. Links
That's a +43 with a 255 tire. Definitely had to roll the fenders. With +38 in front, you will have to roll the fenders and I hope you have some coilovers. The rear will be fine.
Old Nov 23, 2006 | 08:17 PM
purerx7's Avatar
Registered User
^ not true, i have +38 with stock suspension, havent rolled the fenders and I have had 0 problems.
back when my car was stock
Old Nov 23, 2006 | 08:50 PM
Mahjik's Avatar
Mr. Links
What tire size? I would be curious if it was larger than a 235.
Old Nov 23, 2006 | 09:18 PM
ptrhahn's Avatar
Stock suspension might be one thing, but who wants that?
One a lowered car, you'll NEED rolled fenders... I don't give a hang what anybody says. If you drive the car in anything but in a straight line or go over any bumps with the wheels turned, it'll catch the lips. Trust me.
I've run all of these combos, and they ALL rub or have the potential to catch SOMEPLACE. FD fenderwells are just small, and the car was designed for higher offsets. I'd consider "conservative" to start at +45.
245/40/17 on 17x8 +38
235/45/17 on 17x8 +38
235/45/17 on 17x8.5 +37.5
255/40/17 on 17x9 +45
275/40/17 on 17x9.5 +42
235/40/18 on 18x8.5 +40
255/35/18 on 18x9 +42
285/30/18 on 18x10 +50
Old Nov 23, 2006 | 09:37 PM
rynberg's Avatar
18x8.5+38 235/40
18x9.5+38 265/35
Those offsets aren't what Tire Rack suggests or recommends. Those offsets fit within their allowable range on the stock suspension. Ideal offset would be +50.
With those wheels above, I would run 245/35 up front (8.5" wide wheel). Like Ptrhahn and Mahjik say, you should roll the front fenders.
Old Nov 25, 2006 | 02:03 PM
eli_eli's Avatar
tks for the info guys.. worst case scenario i'll roll the front fenders but i think it will all work out ok.. btw, those specs above is what i go from tire rack for a BBS wheel for 93 mazda rx-7.. yes they may not be perfect but usually from what i've seen from them as far as suggested specs, wheels/tires fit well without any extensive mods if any on some cars..
Old Dec 17, 2006 | 04:04 PM
purerx7's Avatar
Registered User
tires are a 245
Old Dec 17, 2006 | 06:38 PM
battleaxe's Avatar
Rock Slaggin' Jam Rocker
a 18x9 +20-+25 u can fit a 255 tire on there
we just did a 17x9 +17 with 225s on omochis car and looks the ****
he had a 17x9 +45 with a 245 tire and he wants a 20mm spacer
and if u want wider tires roll the fender, not a big deal man
Old Dec 18, 2006 | 02:25 AM
Rotor Nut.
the fd wheel fitment guide says they will fit fine. a 9" wheel on the rear can go as low as +31 offset. atleast thats what the guide said.
Old Dec 18, 2006 | 08:04 AM
Mahjik's Avatar
Mr. Links
tires are a 245
Good luck if you ever lower the car. You'll definitely need the fenders rolled.
With a 9" wheel with +43, I was eating the fender running a 255 up front. You can make larger tires work up front (or in the rear), but it takes some effort.
Old Dec 18, 2006 | 09:46 AM
Rotor Nut.
so basicly the wheel thread is wrong?
here is a pic of a guy running 18x9 +41 front with a 255, it looks like it clears easily. here is his thread link. pic is on page 4
https://www.rx7club.com/forum/showth...highlight=volk
Old Dec 18, 2006 | 12:16 PM
rynberg's Avatar
STFU. Seriously.
This is a thread about PROPERLY fitting wheels and tires, not trying to achieve the newest FAD non-functional look.
Old Dec 18, 2006 | 12:30 PM
purerx7's Avatar
Registered User
yah my car is stock suspension, if it was lowered i would have some serious rubbing problems, thats why im getting some new advans.
Old Dec 18, 2006 | 12:41 PM
Mahjik's Avatar
Mr. Links
Fender rolling is a must and it also depends on your suspension setup. You'll see his car is higher than mine. Here's mine 17x9 +43 with 255's:
Old Dec 18, 2006 | 04:43 PM
Rotor Nut.
i know this is a little off topic, but i am intrested in this thread because i follow the fd wheel fitment sticky and it seems to be off a bit. i just bought a 18x9 +33 wheel for the rear with a 255 tire. i am worried about rubbing. the fd wheel thread said i was good till +31 offset.
pjr
13
Sep 3, 2015 11:44 AM
