Hoses
Old Mar 6, 2002 | 03:31 PM
82mazdarx7's Avatar
Im Rick James Bitch
Question Hoses
Hoses
I was looking to buy some hoses from hosetechniques.com. My friend told me that they only make them for turbo II and third generation rx-7s. Does anyone know where I could get som sky blue hoses for my first generation 82 mazda rx-7.
Old Mar 6, 2002 | 04:15 PM
Pele's Avatar
Right near Malloy
Yeah. I want hoses that match the air cleaner box...
Old Mar 6, 2002 | 07:27 PM
Pittdp's Avatar
Hoses like this???
Is this what your looking for?
Old Mar 6, 2002 | 11:49 PM
smnc's Avatar
EliteHardcoreCannuckSquad
You can order ANY amount of hose you want.
What your friend probably meant is that they only have pre-built kits to replace all the hoses on 2nd and 3rd gens.
We should all e-mail HoseTechniques and tell them to make us a kit...
Old Mar 7, 2002 | 09:16 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
I just go about 2 miles down the road, and I have big river rubber and gasket. They GOT EVERYTHING, you can even take an intake manifold to them and they can make a gasket in like 10 minutes I love that place...
Old Mar 7, 2002 | 10:28 PM
smnc's Avatar
HoseTechniques uses high quality Silicone hoses. MUCH better than rubber...
Old Mar 8, 2002 | 12:04 AM
Pele's Avatar
Right near Malloy
Im after what Pittdp's got in silicone.
I wanna replace ALL the vacuum lines with it, as well as anything else I can get away with replacing with it. (Heater hoses, Radiator hoses. If stuff like that isn't readily available, then forget it. but defenately the vacuum lines.)
Old Mar 8, 2002 | 02:12 PM
yayarx7's Avatar
Are you Nucking Futs?
I have only seen the radiator hoses and heater hoses in factory like rubber. You can get universal silicone vaccuum line at pep boys.
Do they make silicone heater hoses for the T2? If so they should fit right on a SE or a 79-82(no oil/water cooler).
Old Mar 8, 2002 | 08:43 PM
Pittdp's Avatar
I got mine through www.mazdatrix.com
Old Mar 8, 2002 | 08:47 PM
Felix Wankel's Avatar
Super Newbie
Just buy the hose by length. Those kits are expensive, and they give you dumb **** like a hood prop rod cover
Old Mar 8, 2002 | 08:55 PM
Pittdp's Avatar
Ijust went to http://www.hosetechniques.com and there site sucks, non of the links work
Old Mar 9, 2002 | 01:44 AM
smnc's Avatar
Never had a problem with the site...
Good hose tho, from what I hear...
I don't suppose anyone knows offhand how much, and what size, hoses I need to replace all my 18 year old factory rubber on my '85 -SE?
I know I have a vac leak somewhere 'cause I have an intermittent idle fluctuation. I figure instead of bothering to track down every damn leak that comes along, I may just as well replace ALL the vac hoses now and save myself the headaches later on...
Old Mar 9, 2002 | 05:44 PM
yayarx7's Avatar
Looking at the kit that hosetechniques has for the T2 it seems those kits are worthless. They replace like 2 vacuum lines and the rest is coolant overflow bottle and window washer line, not to mention the ever-important prop rod cover. According to their pic there is no red underneath the intake manifold where all the important, need to be replaced, vacuum hoses are on the T2. For $100 you could just hit pep boys and use the rest of the money for a intake kit.
Old Mar 9, 2002 | 08:27 PM
Pittdp's Avatar
LOL , how true
Old Mar 9, 2002 | 08:48 PM
Super Newbie
Actually there is only about a foot of vacuum hose under the intake of a TII. Most of them are part of a metal solenoid rack.
I still think those kits suck. See my above post.
I took my solenoid rack off the TII and ran new vacuum lines. I bought some nice inconspicuous black silicone hose (although my BOV is bright ****** purple )for about 10 bucks and did all 6 of the vacuum lines that remained
Old Mar 9, 2002 | 11:17 PM
Pittdp's Avatar
Thats why madzatrix's is a good place to by them from since the tubing runs like 2.00 per foot.
Old Mar 10, 2002 | 01:31 AM
smnc's Avatar
If I'm not mistaken, Mazdatrix sells HoseTechniques hose?
So... DOES any of you guys know how much hose my -SE will need? I'm kinda lazy and don't wanna have to figure it all out
Old Mar 10, 2002 | 05:28 PM
85RX7GS's Avatar
I've seen them at MazdaTrix and they've also got them at a local performance shop near me.
Old Mar 11, 2002 | 04:11 PM
82mazdarx7's Avatar
Im Rick James Bitch
I want to get them from hosetechneques but if they are better somewhere else than I will get them there
