Turning over Problems.
Old Nov 13, 2006 | 04:14 PM
Rx7Dummy's Avatar
Newbie
Sup guys. I drove my car one night (RX7 1991-non/turbo) , went to start it two days later. And got nothing. The only response I get is a *whining* sound while turning the key on. I've posted here before.. a guy mentioned it may be flooded. I ended up taking it to a mechanic after following *Un-flooding RX7's* manual and still nothing. The mechanic says Compression problems. Is there any way to check this or be sure?
Any suggestions or other ideas besides non-compression. Please, feel free..
Old Nov 13, 2006 | 04:30 PM
rx junky's Avatar
Shapeshifter
pull the spark plugs out and poor oil down in the holes well thats what i had to do with mine and it started right up
Old Nov 14, 2006 | 08:56 AM
Dr4900n's Avatar
If your car is flooding you may want to install a Fuel Cut-off switch.
It simply cuts power to the fuel pump when you open the circut. This way oil is still injected and the starter will crank the engine.
Alot faster than pulling your plugs all the time.
I think that whinning sound is your fan??
RyanFox
Sep 18, 2015 09:09 PM
Farkel
Sep 16, 2015 06:16 PM
erevos
Sep 15, 2015 09:19 AM
sinistersam
Sep 13, 2015 07:17 PM
The1Sun
Sep 7, 2015 10:21 PM
