Ok you know it all audio guys... this is for you.
Old Mar 6, 2002 | 01:10 AM
nipplebandit45's Avatar
Talking Ok you know it all audio guys... this is for you.
I just got the Kenwood 5 1/4 Excellon spakers with tweeters. yquestion is at what angle would be the best sound rom th tweets. Flush in the dash pointing straight up, on top of the dash strait up, or on top of the dash at a 80 deg angle pointing into the cab, or on top of the dash at about a 20 degree angle pointing into the cab. Or shoul I aim them at thewindow?
Right now I hve them stuck on the dash pointing in at the 80 degree angle and it sounds a HELL of a lot better than it did without them. the 5 1/4's are in the stock front mmounting point. took a bit of creative ust of a abre saw, but everythning sounds nice and happy... but i want the most from my tweets. this s the firt time ive ever messed with them in 27 years.
Mike
Old Mar 6, 2002 | 01:23 AM
Directfreak's Avatar
I am a Jeeper Now.
I recommend you have a friend help you, and play with the locations (while holding the tweeter in hand) until you get the right sound you like.
Nobody can tell you what you do or do not like.
It's simply a matter of taste.
One recommendation, make sure they point to a position no higher than you neck/shoulders. Otherwise, after a while the tweets near your ears will drive you crazy (with headaches).
Old Mar 6, 2002 | 05:00 AM
Powerslave's Avatar
Best place for tweeters is in the middle of your round air vents on either side of the front dash I have a set running thru the vents in the rear near the rear speakers as well, works well
Old Mar 6, 2002 | 05:13 AM
id be putting them in the dash hitting the windscreen. Best bet slap some blutack on the back of it and move it around till you get the right position for you.
Old Mar 6, 2002 | 09:48 AM
mar3's Avatar
Administrator
The one thing everyone is missing concerns only those interested in a true SQL car. The tweeter for each side should not be more than 6" away from the speaker on each side that is generating vocals for your car. The imaging of your front soundstage will not be as clearcut if this "rule" is violated. Believe it or not, your ears and brain can pick up the .5 microsecond in difference of time it takes for a sound wave to come from two different spots and reacts accordingly trying to lock down the different locations...
Old Mar 6, 2002 | 10:31 AM
jimmyv13's Avatar
Round&Round not Up&Down
This is correct. Do not seperate the tweet and the midbass. Build a speaker pod for the component set and put it down where the factory fronts are.
Here is a thread from a while back. It has a bunch of very good info.
Old Mar 6, 2002 | 10:32 AM
rotorhead's Avatar
so would door mounted pod speakers sound better? how would one go about making the pods? especially if they have manual windows? the rule of thumb i've always used is to point the driver's side speakers at the passenger's head and vice versa.
Old Mar 6, 2002 | 10:53 AM
jimmyv13's Avatar
The problem with door mounted pods is that one is very close to the driver and the other if pretty far away. The sound from the drivers side pod will reach your ears before the passenger pod will and it sounds....well.... kinda weird, lacking of the correct verb. The distance from the R & L speakers to the listener should be very close, within inches if possible. Read the thread I posted above and I explained it better in there.
Old Mar 6, 2002 | 11:44 AM
rotorhead's Avatar
aha! you posted while i was still typing... i'll go check. as far as the distance thing is concerned, i've always been told that the sound can be cleaned up somewhat by the aiming. the off axis sound of a speaker(nearest) is offset by the onaxis sound of the other speaker(farthest). but i'll check the other thread too....
"so now you know. and knowing is half the battle! G.I. JOOOOOOOOOOOOOOE!"
Old Mar 6, 2002 | 11:50 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Thats how I had mine in both my 7's. But the problem with that is, not that it really matters tho. You can hear the left and the right perfectly when on the drivers side, get on the pass side and all you hear is the right..
Id recommend putting them in the vents, cuz who gives a **** about the passenger Plus they are hidden and someone would be ******* wont be able to walk by and say Humm? I like them...
Old Mar 6, 2002 | 11:52 AM
mar3's Avatar
Administrator
Here is another option...pretty labor intensive, though because of all the metal that gets cut to stuff the 6.5" 2ways and the 4" sub in there...
I'm rethinking my ribbons which is why there's a big square hole near the top of the door panel...
Old Mar 6, 2002 | 12:03 PM
I am a Jeeper Now.
Best Place for Speakers...
Enough Said..
And yes - That is an RX-7
Read more about this BAD BOY 12A Turbo HERE
Old Mar 6, 2002 | 12:16 PM
rotorhead's Avatar
OMG! that interior is un-freakin'-believable! jeez, now i gotta clean up the keyboard.......
Old Mar 6, 2002 | 01:38 PM
Richard Miller's Avatar
Damn, it did start!
hey thanks for that picture I haven't seen that in 2 years.
Old Mar 6, 2002 | 08:27 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
don't put it real close to your ears!
GOD that sounds bad...
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
