alternators
Old Mar 6, 2002 | 01:04 AM
journey's Avatar
alternators
Ok, i'm looking for a new high output alternator for an rx-7, but i haven't found any online shops that have them, or even have suggestions on what to find. I need a high output alternator because i have a system pushing ~1600W RMS at max(normaly i dont run it nearly that loud though). I'm looking in the 140-160A range for an alternator, at at least 70A at idle. Also something that can preferably handle the load of being put to 6-8k rpms once in awhile without burning up.I know running the alternator really fast is a good way to heat it up and burn it out.
Any suggestions would be great, thanks.
Journey
journey at sjsubeta dot com
Old Mar 6, 2002 | 08:55 AM
LoSRx7's Avatar
Check out
www.egrproducts.com
LoS
Old Mar 6, 2002 | 09:07 AM
Ryde _Or_Die's Avatar
Aren't there local places everywhere that rebuild alternators? I know there are here. Can't they just beef up your current alternator? Just an idea if they can.
Old Mar 6, 2002 | 10:12 AM
LoSRx7's Avatar
There should be local shops that rebuild. You can't get much more from a stock rx7 alternator, prob up to 20 more amps. Like I've posted before, i'm currently have a 200 amp alternator that was from a Ford Contour. It was 120 amps stock rewound to 200. It was done at www.egrproducts.com. I'm currently doing ~3000 watts RMS. So i needed at least a 180 amp alternator.
LoS
Old Mar 6, 2002 | 05:24 PM
journey's Avatar
How hard was the instalation of the alternator, since it was from a different car? I've never touched an alternator before so i have no clue, although in the rex it looks like there is a decent ammount of room there.
Did you need anything special like different mounting or longer pully?
Thanks
Journey
Old Mar 6, 2002 | 06:45 PM
LoSRx7's Avatar
Mounting was a little bit time comsuming, prob a hour. They provided the right size pulley with the alternator and supplied a wire diagram on hooking it up. The only thing that needed to be changed was the right side (drivers side) mounting bracket. All you need was a straight bar instead of the curved one. They also supplied the washers for the left side, but i still needed to add 2 little ones( no biggie).
The Rx7 alternator has its mounting arms at the 1 o'clock and 7 o'clock positions, the contours alternator has the 7 o'clock, but the other one is at the 4 o'clock position. The 4 o'clock position lines up right above the hole where the stock curve bar attaches to on the engine. Thats y u need a straight bar.
I wish i had pics, it would be easier to explain.
Good Luck
LoS
Captain Hook
13
Oct 4, 2015 06:35 PM
Robrods64
Oct 2, 2015 07:56 PM
WANKfactor
Sep 29, 2015 01:14 PM
