anyone with electrical advice please...
Old Nov 12, 2006 | 07:58 PM
foxstarr's Avatar
Question anyone with electrical advice please...
hey peeps, anyone with electrical/wiring knowledge please help me...
just got new windows switches for my 89 non-turb vert;
(haven't had switches since acquiring the car, used to use a teeny-tiny flat-head to push the little thingy up or down to operate the window til it sparked and scared the isht outta me then i stopped using the flathead & ordered switches on ebay)
anyways i hooked them up and nothing; so i got a little light tester thing to see where i did have power (on the door) and found power to my doorlocks, door-panel lights, and well thats about it.
if i shorted out the line for the windows or whatever,
how do i get power back in that wire? do i dare run a new line from my battery err... myself?
i put an amp in my trunk aboout 6 months ago
(yes, it works!) for my little system so i'm not totally ignorant re: wiring, but i dont have a clue how to make the windows work.
anyone with electrical advice please...anyone with electrical advice please... anyone with electrical advice please...
Old Nov 12, 2006 | 08:14 PM
Black91n/a's Avatar
HAve you checked the fuse? That's the first thing to do.
Old Nov 12, 2006 | 10:14 PM
foxstarr's Avatar
oh yes, both main box and driverside underdash box...all good.
next...
Old Nov 13, 2006 | 09:22 AM
Rob XX 7's Avatar
FC guy
if you sparked the thing there should be a bad fuse, did you pull the fuse and change it or just look at it?
Old Nov 13, 2006 | 10:38 AM
White94RX's Avatar
BMW Tech
Yeah, sounds like you blew a fuse. There's usually a separate fuse for the power windows. Then there's that off chance that the switch you bought is bad.
Old Nov 13, 2006 | 03:29 PM
jl1rx7's Avatar
FLY NAVY
Veteran: Navy
take the switch apart then clean the contacts with a eraser and rubbing acholol. then check all the wiring and see if you can notice any loose ones. Hope this helps.
Old Nov 15, 2006 | 12:27 AM
foxstarr's Avatar
fuses are all good...connectors are clean...switches are good...
Andrew7dg
Aug 6, 2017 01:41 PM
Zinraf
Oct 1, 2015 01:09 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
