temp gauge questions
Old Nov 12, 2006 | 05:59 PM
VacavilleFC's Avatar
okey i'm going with a smaller aftermarket steering wheel which will block my gauges i want to install a aftermarket temp gauge, i just want to make sure i'm understanding this all correctly, the temp sender by the oil pedestal is for the gauge and the one on the water pump itself is for the ecu correct? so disconnecting the one for the dash will not affect operation? or should i just splice the aftermarket wire in with the old one so both gauges work?
Old Nov 12, 2006 | 07:25 PM
Funkspectrum's Avatar
You're probably going to need a sender to replace the OEM one. AFAIK, you won't be able to splice the wires together because of a difference in resistance.....
Old Nov 13, 2006 | 01:56 AM
NZConvertible's Avatar
I'm a boost creep...
You have to use the sender that comes with the gauge. You can't use the stock one.
Old Nov 14, 2006 | 03:28 PM
sweet, thanks guys. i'll have more gauge questions coming soon
Old Nov 14, 2006 | 06:21 PM
Dak's Avatar
Dak
Information Regurgitator
I think it would be best to drill and tap a hole for the sender that comes with the aftermarket gauge. I think the best place is in the water pump housing under the thermostat.
Snoopy FD
Dec 8, 2015 01:45 PM
LMBTG
Aug 15, 2015 01:43 PM
