Anyone else have one hell of a time bleeding the clutch?
Old Nov 12, 2006 | 01:59 PM
Dr4900n's Avatar
Finally got a new battery and then I went to bleed the clutch.
That damned TMIC in the TII gets in the way of my pliers and the nipple. And my ratchet sockets are too shallow to break it free.
Anyone have suggestions on how to make it easier?
Old Nov 12, 2006 | 04:09 PM
HAILERS's Avatar
HAILERS
Remove the intercooler and use a box, 8mm size wrench. I might be wrong about the size.
And or remove the oil filter for access. I mean, it just spins off and you then, have lots of room. Box end wrench.
I'm not real sure what your doing with pliers. Odd.
Old Nov 12, 2006 | 04:48 PM
88rxn/a's Avatar
tom port.. AKA streetport
just dont strip it with pliers!!
be carefull...
Old Nov 12, 2006 | 05:00 PM
boosted1205's Avatar
Use the right tools for the job.
Old Nov 12, 2006 | 05:02 PM
staticguitar313's Avatar
R.I.P. Icemark
8mm confirmed, its not hard . . . i bled a clutch in a few minutes.
Old Nov 12, 2006 | 05:10 PM
dizflyaznboi's Avatar
when i bleed my clutch i just took the top off the master clyinder, and just pumped the clutch, i dont know if this is the correct way but it works for me. Maybe this can help some.
Old Nov 12, 2006 | 05:17 PM
Bleeding Clutch
Recommend replacing bleed screw with speed bleeders screw to prevent air in lines.
Old Nov 12, 2006 | 05:25 PM
Secondmessiah's Avatar
Rotary enthusiast
heres how i did it
i have two extenders for the rachet, so i loosened it up using that
then i attached a bleeder kit w/a check valve onto it (make sure its attached the right way) and let it hang down into my drain pan
pump the clutch slowly while a buddy watches the resevoir, telling you when to stop and refill
when done, you have to reach down and hand tighten the valve while turnign the hose with the valve, so that the hose doesnt come off
when its tight, pop off the hose and snug up with a wrench
Old Nov 12, 2006 | 06:49 PM
Dr4900n's Avatar
Yeah, I was able to get a 8mm socket on it, it was just too shallow when I went to put the ratchet on it.
I also just bought 10' of 3/4" tubing for $4 (cheaper than a bleeder kit), cut the top off a water bottle, cut 2 feet of hose, attached with some duct tape so it dosen't fall out of the bottle.
I was told that you're supposed to pump the clutch and let it go, open the nipple and let it bleed, close it, pump clutch again and let it go, rinse, repeat.
I guess I'll take the TMIC off tommorow...
Thanks for the replies.
Old Nov 12, 2006 | 08:11 PM
Rotary enthusiast
the bleeder kit saves your the trouble of opening and closing the valve a bunch of times
i used and extra-deep socket (its worth buying a set of those)
Old Nov 12, 2006 | 10:03 PM
You don't need to use any bleeder kit if you replace bleed screw with speed bleeders screw to prevent air in lines. You can pump clutch all you want and no air will enter lines.
Old Nov 12, 2006 | 10:31 PM
MazterDizazter's Avatar
I'm your turbo lover
Jeez I was scared for a little while; I gotta bleed the clutch this week.
cristoDathird
28
May 30, 2019 08:47 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
