stabbing cas
Old Nov 12, 2006 | 01:26 PM
stevensimon's Avatar
stabbing cas
i just set tdc on my new rebuild and im not quite sure on how to stab the cas propperly. can someone tell me please? thanks
Old Nov 12, 2006 | 02:26 PM
RotaryEvolution's Avatar
Sharp Claws
pull the cover off the CAS, line up the scribed dot on the gear to the embossed line in the cast aluminum housing(both are at the bottom end of the CAS) and note the position of the teeth vs sensor inside the CAS. drop the CAS in holding the shaft to keep it from spinning and keeping the alignment bolt in the middle of the adjustment slot, once the gear engages the teeth in the timing cover allow the CAS to spin slightly clockwise and tighten the adjustment bolt for the CAS up loosely in the middle of the adjustment slot.
Old Nov 14, 2006 | 07:14 PM
thanks buddy!
Old Nov 14, 2006 | 07:23 PM
snowball's Avatar
I live in the lounge...
the FSM could have told you everything you needed. should always check there first for basic stuff.
Old Nov 14, 2006 | 07:28 PM
alexdimen's Avatar
TANSTAFL
double check work with a timing light on L1 wire lead
Old Nov 14, 2006 | 09:13 PM
88rxn/a's Avatar
tom port.. AKA streetport
wow, sounds like a process???
probably easy....*shrug*...
guess ill find out in a few months.
Old Nov 14, 2006 | 09:43 PM
papiogxl's Avatar
What's the point??
Its really easy.
Old Nov 14, 2006 | 10:44 PM
Sideways7's Avatar
It seems confusing until you actually do it. It is suprisingly easy to do.
NEWGENRX7
Jun 26, 2019 12:20 AM
PinkRacer
43
Oct 1, 2015 09:13 AM
Sammy Built
Haltech Forum
Sep 28, 2015 03:18 PM
immanuel__7
Megasquirt Forum
14
Sep 7, 2015 07:25 PM
